TLR 22T 2.0 Stadium Truck >
Old 10-12-2015, 01:14 PM
  #886
SUPERLOOPER's Avatar
Originally Posted by MNiceGuy
I do but for no real reason. I think those are there to keep debris from kicking up to the chassis but there's no debris where I race. I just think they're kind of cool and decided to keep them on.
Thanks.
SUPERLOOPER is offline
Old 10-13-2015, 05:15 AM
  #887
[[john]]'s Avatar
Trader Rating: 24 (100%+)
This might be a stupid question but you can apply the EXO 22 conversion to the 22T and still have everything within legal dimensions? I was aware of the kit but always assumed it was buggy only.
I don't believe there is minimum dimensions?
[[john]] is offline
Old 10-13-2015, 08:07 AM
  #888
MNiceGuy's Avatar
Oh I have no idea. I think the Exotek conversion is pretty cool but thought this whole time it was buggy-specific. If I can run it on an ST without anyone making a fuss about it then I need to rethink things a little.
MNiceGuy is offline
Old 10-13-2015, 08:15 AM
  #889
MNiceGuy's Avatar
One more quick thing:
Can I buy replacement spoilers for a MM 22T? I found TLR8120 but the picture doesn't show the tab that fits over the rear body posts. To be honest I'm not sure how one would attach the spoiler shown in the photos for 8120.
MNiceGuy is offline
Old 10-13-2015, 09:03 AM
  #890
Mudcat981's Avatar
TLR did not make any replacement spoilers for the 2.0. Just buy the TLR8120 and mount them on the back of the body. The kit spoiler is very weak and gets damaged quickly. This old TLR8120 spoiler last forever. I tore-up my original spoiler the first race day. Replaced it with this one and have been running it for 6 races without any damage.
Mudcat981 is offline
Old 10-13-2015, 09:12 AM
  #891
MNiceGuy's Avatar
Thanks for the info!
How do you attach 8120?
MNiceGuy is offline
Old 10-13-2015, 09:17 AM
  #892
Mudcat981's Avatar
Bend about 1/4" from the bottom at a 45 degree angle. Then I drilled 4 holes (2 for each side) and mounted with small screws and nuts. I trimmed the part across the center section to make clearance for the body pins.
I will try and take a picture tonight and post it.
Old 10-13-2015, 11:21 AM
  #893
The Jconcepts Gurney spoiler will also mount onto the back deck of the 22T body using screws and plastic nuts, but the body will deteriorate much more quickly than with the stock spoiler because of where the crash loads are focused. Guess that gets you closer to a new body and stock wing, though.
Not sure if you've already seen these tips but they help a LOT: http://losiracing.blogspot.com/2015/...nting-tip.html
Christophoclese is offline
Old 10-13-2015, 12:48 PM
  #894
I done that to my body when it was brand new and the screws ripped thru the body on my first race .
Dirtraycer is offline
Old 10-13-2015, 04:35 PM
  #895
tsair's Avatar
Are you guys using the spoiler for rear traction or more to keep the nose up in flight? I don't run a spoiler at all, and it seems to drive OK. Maybe it nosedives a little too much, but the car isn't bad.
tsair is offline
Old 10-13-2015, 05:02 PM
  #896
Length is 15.25" min, 18" max
Wheelbase is 9" min, 11.5" max
Per section 8.7.2.1 on page 50 of Roar rules.
No idea of where the Exo buggy chassis is?
Dave H is offline
Old 10-13-2015, 08:18 PM
  #897
MikeR's Avatar
Trader Rating: 15 (100%+)
The EXO22T will be released later this week. 5mm longer than the buggy which makes the truck easier to drive.
MikeR is offline
Old 10-13-2015, 08:38 PM
  #898
slowsrc is offline
Old 10-13-2015, 11:22 PM
  #899
[[john]]'s Avatar
Bummer, I should have waited a couple of weeks
[[john]] is offline
Old 10-14-2015, 09:16 AM
  #900
Did you use washers between the screw cap and the wing surface?
Did you leave plenty of slack (screw and nut should NOT be cinched down)?
Careful to ream the screw holes as tight as possible?
Ever since I started doing this my 22T MM wings went from lasting about 3 weeks to lasting almost as long as the bodies themselves, while racing twice a week.
