TLR 22T 2.0 Stadium Truck >
Old 09-28-2015, 11:26 PM
  #871
I)arkness's Avatar
Thumbs up
Originally Posted by pink_sleeve
Does the kit come with 1 or 2 sets of wheels? Yellows?
2pairs of yellow rims
I)arkness is offline
Old 09-29-2015, 11:53 PM
  #872
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by RandyJones
Tyler built his truck to kit setup. We had to run spring adjusters almost all the way done to get kit ride height. Is that right? He is gonna run it next weekend on a track that is low-med grip. Went to 27.5 in rear shocks like suggested. Should truck be pretty decent on that style of track?
Yes, that'll be a good place to start.
Originally Posted by beedawgg
Noob question. What tires would i use for the front on an indoor clay track?? I've only raced on outdoor dirt and i use ribbed tires for that. Would I use the same style or use the same as I would for the rear??
Thanks for helping this noob out!!! lol
Dirt Webs front and rear if you can find them. Compound depends on the track, but it is usually gold, and sometimes green.
One set (or 2 pairs, or 4 wheels), yellow.
Frank Root is offline
Old 09-30-2015, 01:14 AM
  #873
tsair's Avatar
Finally got my 22T 2.0 on the track today, fun car to drive and handles very neutrally in stock setup. 21/76 was geared way too low for my 13.5t motor, even at full timing and punch motor was running at 120-130 deg and I could barely clear jumps. Slipper works way better in the truck over the 22SCT2.0.
Really enjoying the truck, so fun and easy to drive. Great job TLR!
tsair is offline
Old 10-01-2015, 04:23 AM
  #874
bwillenb's Avatar
Trader Rating: 53 (100%+)
Default Losi 22t 2.0 Differential noise question
Morning all,
Just picked up my first new 22t and I have a question about the differential. When you spin the rear axles on a 22 style diff should there be a sort of grinding feel and soft noise? Video link below.
With my 1/8 scale vehicles all of the diffs have always turned and felt smooth upon build completion. Appreciate any insight anyone could give.
Thanks in advance,
Brian
https://youtu.be/Jy_YZ1_MOvA
bwillenb is offline
Old 10-01-2015, 12:18 PM
  #875
How can you tell if your diff is too tight ?
Dirtraycer is offline
Old 10-02-2015, 08:48 AM
  #876
Stevomatik's Avatar
First race with this bad boy tonight...
Stevomatik is offline
Old 10-02-2015, 03:44 PM
  #877
Trader Rating: 166 (100%+)
Attachment 1320689
Nice..
jpcopeland1 is offline
Old 10-04-2015, 07:34 PM
  #878
Default AstroTurf set up
We just started racing on astroturf. Does anyone have a set up for this surface?
cheetahz24 is offline
Old 10-05-2015, 07:58 AM
  #879
Make sure your transmission case is not screwed closed too tightly. I had this problem and back the screws a half turn just to start.
Notbrick is offline
Old 10-08-2015, 08:40 AM
  #880
MNiceGuy's Avatar
Originally Posted by nitrousdave
I did see that and the case is clearly part of the problem. I dremelled mine a little last night and after doing that it was clear that the lower idler was rubbing a little even without the trans in the chassis because it was much freer afterward and stayed that way even after bolting it in the chassis. To me there are two things going on though, the case and the case not fitting the chassis correctly and getting stressed when tightening it in the chassis. Hopefully Frank is still working on this issue and TLR will offer a revised case or something.
Any update on this from TLR?
MNiceGuy is offline
Old 10-10-2015, 03:34 AM
  #881
R/C Tech Elite Member
[[john]]'s Avatar
Trader Rating: 24 (100%+)
I've just ordered the Exotek EXO22 Mid Conversion for my Truck, has anyone done this conversion on a Truck here before? Any pictures?
[[john]] is offline
Old 10-11-2015, 05:08 PM
  #882
trutledge83's Avatar
Attachment 1320689
lookin good
trutledge83 is offline
Old 10-12-2015, 08:30 AM
  #883
MNiceGuy's Avatar
This might be a stupid question but you can apply the EXO 22 conversion to the 22T and still have everything within legal dimensions? I was aware of the kit but always assumed it was buggy only.
MNiceGuy is offline
Old 10-12-2015, 12:42 PM
  #884
SUPERLOOPER's Avatar
Do people run the body side skirts on the 22t 2.0?
SUPERLOOPER is offline
Old 10-12-2015, 12:52 PM
  #885
MNiceGuy's Avatar
I do but for no real reason. I think those are there to keep debris from kicking up to the chassis but there's no debris where I race. I just think they're kind of cool and decided to keep them on.
MNiceGuy is offline
