TLR 22T 2.0 Stadium Truck
#61
OK, talked to my LHS... got the parts needed to upgrade my 1.? to a full blown 2.0 on order can't wait to try these changes....
#65
$299.99 @ AMain for pre-order
AMain Hobbies - Losi 22T 2.0
Features:
Updated suspension geometry
22™ 2.0 caster blocks with 22T™ 2.0-specific spindles
Wider rear arms for easier direction changes
Gen II shocks with machined piston and x-ring seals
Bell crank steering system for smoother response at every speed
Hard-anodized 7075-T6 aluminum chassis
Updated ball differential with tungsten carbide balls and larger diff rings
TiCN shock shaft, inner hinge pins, and outer threaded hinge pins
Adjustable, hard-mount battery holder
Aluminum rear camber block
Narrower rear hex with less wheel off-set
Aluminum ball stud washers throughout
Mid- and rear-motor mount parts included
Metric hardware
22T 2.0 body
Love the Body, not as sexy as the 1st XXX-T body but close.
Features:
Metric hardware
22T 2.0 body
#67
Still I much sexier body than the one on the new AE T5M
Well Said Most people that have sctphobia have either not owned one or didn't know how to set one up correctly. ST was one of my favorite classes (both electric and nitro). As much as I didn't like it when the class starting dieing all those years ago, I would miss SCT more than the ST class.
#68
I have a T5M on preorder but now I am reconsidering. I am sure both trucks will be great, but TLR really has included a lot of stuff right out of the box that make the 22T very appealing, not the least of which is the ability to go RM or MM out of the box - and I think the price is very reasonable too considering what they include.
#69
Suspended
22T 2.0 looks a lot sexier than the T5M.
#70
That's what makes SC so much fun is the contact. I'm not talking about punting people. You can run side by side, put the wheel to someone (without completely punting them) without taking you both out, use them as a brake, etc. Once you "learn" how to drive SC, it's a lot of fun to trade paint! Buggy is for clean racing, but in SC....IT'S ON!
#71
#72
#73
And just like the B5M, it wont have a usable setup for months. No thanks. I see nothing in the new parts that Phends Nats winning setup from last year in Mid-Motor that will not translate damn good into the new truck. AE will have a centro T4.2 setup before they have a good T5M setup.
#74
Both the T5M and the 22T 2.0 will be great. Neither has been released yet, but the fanboy trashing of the evil other truck is already there. Sad but true, you really can't read any AE and TLR threads on rctech if you are just looking for proper information.
By the way, it is spelled Schuur Speed like in NitroLuver's sig, not Shurr Speed.
