TLR 22T 2.0 Stadium Truck >
Old 05-19-2015, 09:55 AM
  #646
Mudcat981's Avatar
Originally Posted by RBraswell
Right now I have a Savox 1578TG does the job. I may downsize to a smaller profile server with a higher speed.
+1
Mudcat981 is offline
Old 05-19-2015, 09:59 AM
  #647
Mudcat981's Avatar
Originally Posted by dglewis89
Is this normal for the steering to have 3-4mm of play around those spacers ?
3-4mm? That is 1/8-5/32 inch, that is almost impossible if the kit is put together correctly? There is however some play, more like max 1mm. If you have more than that then you have something put together wrong.
Old 05-19-2015, 10:47 AM
  #648
68pontiac's Avatar
Originally Posted by mxturd
Just getting into ST, and wondering what is good steering servo for these, should I be looking more towards what i woudl use in SC? or a bit lighter.
Thanks Doug
I've been using the Spektrum S6040 in all my 22 vehicles. I think it's a great servo for the price, my only complaint is that it has a bit of a whining noise when force is being applied to it at idle.
68pontiac is offline
Old 05-19-2015, 11:45 AM
  #649
Originally Posted by Frank Root
The shock stand off issue isn't one I've heard of before. You can use some shims to tighten the steering if you'd like. The kit is a really difficult balance of keeping part fit tight, but making sure it doesn't bind either. One thing is for sure, it's better to have a little slop than a little binding so we error on that side slightly. Also, parts have tolerances, so you might just be at the end of the tolerance range. As for the driveshaft, that's a known (and corrected) issue. Contact product support and they'll get you straightened out on the driveshaft and shock mount.
Good point on haveing play over binding. I gave product support a call and they're sending new parts for all three issues. The guy I talked to also said the standoff issue is new to him. Other than those small things the truck was a blast to build. Thanks
dglewis89 is offline
Old 05-19-2015, 01:30 PM
  #650
"Spanky's Avatar
Thanks Doug
Spektrum s6040. High torque, super fast. Metal gears and cheap in cost! $old
"Spanky is offline
Old 05-20-2015, 09:51 AM
  #651
mvrk28's Avatar
Does anybody run this thing rear motor and still have their mid motor body? If so, wanna trade? I have the rear motor body and I don't anticipate I will need it so if anybody wants to trade let me know.
mvrk28 is offline
Old 05-20-2015, 12:25 PM
  #652
I'd be interested in that swap. I have a brand new uncut and unpainted mm body. Pm me with where you are and we can see about shipping .
Ryan
Wanderer77 is offline
Old 05-20-2015, 01:34 PM
  #653
mvrk28's Avatar
Ryan
Ryan check your PM
mvrk28 is offline
Old 05-21-2015, 11:52 AM
  #654
loloscorsa's Avatar
Hello, I have a question with this model. Is possible to mount a standard 2S lipo (large) with Mid Motor configuration?
Thank you boys!
loloscorsa is offline
Old 05-21-2015, 12:17 PM
  #655
Thank you boys!
I do not think so the only packs that will work with mm is saddle,shorty or brick!
bigco66 is offline
Old 05-21-2015, 12:42 PM
  #656
Mudcat981's Avatar
I believe if you wanted to try you could do this.
Actually if you used the Team Losi Racing 22 2.0 Mid/Rear Battery Mount Set
[TLR231014] $15, you might be able to make it work.
If you cut the front bulkhead to allow the battery to extend through, and the hold down would hold the battery. Of course you would have to mount the RX elsewhere, to the side or near the waterfall.
Not sure what the weight distribution would do.
I would also recomend using the Exotech ESC alum mount.
Old 05-21-2015, 02:49 PM
  #657
Trader Rating: 15 (100%+)
I dont think I'd try to run a full stick in MM. you'd have a hot mess on your hands.
RBraswell is offline
Old 05-21-2015, 04:20 PM
  #658
Mudcat981's Avatar
Richard B.
How was your first run with the 22T 2.0?
Old 05-21-2015, 06:54 PM
  #659
Hi all, could someone give me a good FDR starting point for an 8.5 cheers.
goldy is offline
Old 05-22-2015, 01:45 PM
  #660
1badgoat's Avatar
Got some bodies back from paint...
URL=http://s1126.photobucket.com/user/1badgoat/media/New%20Paint/20150522_103034_zpsndqp81sw.jpg.html][/URL]
1badgoat is offline
