TLR 22T 2.0 Stadium Truck >
Old 05-12-2015, 10:11 AM
  #616
mvrk28's Avatar
Originally Posted by hacker07
Yes, for modified, I run both idlers as aluminum.
No, the bones and axles are different.
Thank you very much for your help. Do you have any experience with the kit of two idlers from Robinson?
mvrk28 is offline
Old 05-13-2015, 11:00 AM
  #617
Trader Rating: 83 (100%+)
Are people running 30/29 ride height like the kit setup says. Running on a pretty smooth indoor clay track.
dpcardoza is offline
Old 05-13-2015, 11:23 AM
  #618
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
I run 30.5 in the front and 29 in the rear.
Frank Root is offline
Old 05-13-2015, 11:25 AM
  #619
Ranger411's Avatar
Trader Rating: 29 (100%+)
I just bought a bought a used 22t from here and want to put the new bellcranks on it. I noticed in the 2.0 product page that the 22t has special spindles. How much different are they from the ones you get from the retrofit kit?
Ranger411 is offline
Old 05-13-2015, 11:35 AM
  #620
Just seemed high to me is all.
Old 05-13-2015, 12:16 PM
  #621
alex4r's Avatar
I believe they are required to get full steering throw with TLR's bellcranks.
alex4r is offline
Old 05-13-2015, 12:18 PM
  #622
TLRacing
Frank Root's Avatar
Tires are bigger on a truck, and thus, the chassis is further off the ground. It is still below "bones level" which is what we always used to set the ride height at.
Old 05-13-2015, 12:22 PM
  #623
Mudcat981's Avatar
The kit comes with a 4mm off-set spindle, the 22T uses a 2mm spindle. I believe instructions were to NOT use the 4mm off-set spindles and continue to use the old 2mm spindles.
If I am wrong someone please correct me.
Mudcat981 is offline
Old 05-13-2015, 01:47 PM
  #624
Trader Rating: 15 (100%+)
Isn't the difference in the spindles an additional mounting point for the ballstud?
RBraswell is offline
Old 05-13-2015, 02:15 PM
  #625
Mudcat981's Avatar
All the 2.0's have two mounting points, the 1.0's only have one.
But the truck uses the 2mm vs. the 4mm.
Old 05-14-2015, 05:32 AM
  #626
[QUOTE=hacker07;14005294]Yes, for modified, I run both idlers as aluminum.
so its not happen stance that I trashed the stock idlers already with a 7.5. I replaced them with plastic again. After seeing this I asked the LHS to order up aluminum
freebird is offline
Old 05-14-2015, 08:54 AM
  #627
Jack Bonhomme's Avatar
I raced my rear motor truck with the 2.5 degree rear toe block and the truck performed better. More corner rotation with less push. Originally I was running 3.5 degrees of rear toe and it planted the rear end a little too firmly in the tighter corners. So this may be a tuning option for other rear motor drivers.
Jack Bonhomme is offline
Old 05-14-2015, 10:22 AM
  #628
It's been awhile since I ran ST but for some reason I thought my old Kyosho RT5 liked around 28/27 or so.
Old 05-14-2015, 10:32 AM
  #629
TLRacing
Frank Root's Avatar
And maybe you did, but the 30-31 range in the front and 28-29mm in the rear is normal for the XXX, 22, T4, and T5 ST's. I think that 28/27 is the non-normal height from my experience.
Old 05-14-2015, 11:37 AM
  #630
68pontiac's Avatar
Hey Frank (or any other Team drivers, really) how big of an impact does ride height really have on vehicle performance? I've been racing for nearly 15 years now but have never used ride height as a tuning aid, I've just set it and left it there and periodically check it. I remember reading the tuning tips for my old XXX buggy and reading the line:
Code:
We have found that ride height is really a minor adjustment. This should be one of the last adjustments after everything else has been dialed in (tuned).
But it seems as though it should have a bigger impact than a "minor adjustment" since it should alter CG, roll center and shock travel. Am I missing a huge tuning adjustment by forever holding onto a 15-year old instruction manual?
68pontiac is offline
