TLR 22T 2.0 Stadium Truck >
Old 05-04-2015, 11:04 AM
  #571
rcdrtrcr's Avatar
Trader Rating: 25 (100%+)
Frank: I race smac trac curious as to what setup you ran there or setup you would recommend. I am soon getting the 22t 2.0
rcdrtrcr is offline
Old 05-04-2015, 03:21 PM
  #572
Trader Rating: 83 (100%+)
It could be me but after my first night of racing I felt the truck pushed a bit more than my liking. Anybody else felt this and what is the best way to remedy this?
dpcardoza is offline
Old 05-04-2015, 03:22 PM
  #573
mvrk28's Avatar
What is your setup? Are you running 27.5 oil in rear shocks? Also if you haven't installed the rear brass pivot it sounds like it's the ticket.
mvrk28 is offline
Old 05-04-2015, 03:28 PM
  #574
Kit setup, 27.5 in the rear, running stock so I'd prefer to not add weight to get it to drive how I'd like.
Old 05-04-2015, 08:43 PM
  #575
mvrk28's Avatar
Are you racing at Outback?
mvrk28 is offline
Old 05-04-2015, 08:46 PM
  #576
Yup. Track conditions were rough last week so it may not have been the best sample as that was my first time with the 22t.
Old 05-05-2015, 08:06 AM
  #577
Trader Rating: 15 (100%+)
what chassis protectors do you all run on your 22t?
RBraswell is offline
Old 05-05-2015, 09:33 AM
  #578
mvrk28's Avatar
Going to pick up the Associated one for mine, I use it on my D413 and it's crazy thick. E1D makes a good one as well.
mvrk28 is offline
Old 05-05-2015, 11:13 AM
  #579
Trader Rating: 36 (100%+)
Gorilla tape here.
nitrousdave is offline
Old 05-05-2015, 12:21 PM
  #580
starspike's Avatar
R17 for the 22 its just a tad short but it works.
starspike is offline
Old 05-05-2015, 02:22 PM
  #581
Mudcat981's Avatar
The JConcepts 22 buggy protector is very thick and will fit the 22T just a little short on the back end.
Mudcat981 is offline
Old 05-05-2015, 10:13 PM
  #582
mvrk28's Avatar
Truck is getting delivered tomorrow, as well as a few other goodies.
Here's what I'm going with in terms of setup:
Tekin RSX esc
Fantom Ion v5 Pro Mod 8.5
Protek RC 100ss Servo
TLR brass mm pivot
VRP X Pistons (2 hole 1.5 front, 2 hole 1.6 rear)
Losi Taper Pin pink compound tires
I'm going to run 27.5 weight in the rear shocks as well.
mvrk28 is offline
Old 05-06-2015, 08:02 AM
  #583
Is a 138oz of torque sufficient for the servo? Thinking about throwing a shorty in there to see how the weight distribution changes the handling. It's about 20 gm less in the front
Old 05-06-2015, 08:08 AM
  #584
mvrk28's Avatar
Might be a little low on torque at 138. A lot of guys are running the Savox 1258tg in their trucks, which does 166. I'm a big fan of Protek stuff so I went with the 100ss, does 168 oz in at .09 seconds, should be sufficient. Also doesn't hurt that it costs a whopping $49.99!
mvrk28 is offline
Old 05-06-2015, 08:23 AM
  #585
It all depends on what type of servo it is you are referring to. All of the new spektrum servos that are out and coming out starting with the s6270 use a true torque or real world torque number. So, if it is 138 oz/in, that is actually how much it lifted from a dead stop. A typical servo uses a calculated torque number which is often actually exaggerated and not what it can lift from a dead stop. I am not saying anyone is wrong, heck, spektrum did this to with its previous line, it just is what it is.
So, 138 on one of the newer metal tab spektrum servos equals around 165-170 of another servo. So, the 6270 for instance is actually the same amount of torque as the older s6040 and no one ever had trouble with that in a truck.
hacker07 is offline
