TLR 22T 2.0 Stadium Truck >
Old 04-14-2015, 02:31 PM
  #451
Mudcat981's Avatar
Originally Posted by 68pontiac
Check out this post on the TLR blog for a tip on how to better mount the wing in mid-motor.
I did something very similar but I used 4 screws and nuts, also used servo tape under the wing to attach to the body. Used one of the triangle pieces for extra support. I mounted 2 of the screws at the farthest outside so the edges would not get ripped off. Also used 2 screws in the middle fore and aft to support the wing with being pulled forward or bent backwards.
I ran it last weekend and the wing was bent all up but still intact.
Mudcat981 is offline
Old 04-14-2015, 02:45 PM
  #452
Originally Posted by FPMX772
I know Coyote is a pretty tight track, do you know what turn motor you will be running yet?
Oh yes, I will be running a tekin R2 6.5t
hacker07 is offline
Old 04-14-2015, 02:57 PM
  #453
"Spanky's Avatar
Oh no!!!! Building came to a screeching halt! The servo horn is way hitting the front bulkhead. Spektrum s6040 with tlr aluminum 23t horn. It doesn't matter what spacers are used for the servo it's bad. Oh no. No way I'm dremeling. It's hitting a good bit.
"Spanky is offline
Old 04-14-2015, 03:01 PM
  #454
sickpuppy1's Avatar
Trader Rating: 32 (100%+)
I shaved off the top of the horn on mine. same servo
sickpuppy1 is offline
Old 04-14-2015, 03:04 PM
  #455
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Something isn't right, I run the same equipment with no clearance issues.
Frank Root is offline
  #456
"Spanky's Avatar
Looks like aluminum horn and one with kit have different angles and size. Gonna swap out aluminum for 23t with kit
"Spanky is offline
Old 04-14-2015, 03:15 PM
  #457
"Spanky's Avatar
Yep. That's what it was. The aluminum servo horn is not 2.0 bellcrank friendly. It's longer and more vertical. The kit horn works with plenty of clearance. Maybe I got a regular 22t horn? Instead of 2.0? Either way swapped out the horn and it's perfect.
"Spanky is offline
Old 04-14-2015, 03:55 PM
  #458
Can we expect set up sheets anytime soon? Im sure this question has been answered in this forum, I just haven't had time to go through it all yet
FPMX772 is offline
Old 04-14-2015, 05:13 PM
  #459
Has anyone noticed excessive bump steer?
tenex is offline
Old 04-14-2015, 05:37 PM
  #460
starspike's Avatar
Maybe you got the 22-4 horn? I run the aluminum horn i ran on my 1.0 and its fine and the same as the plastic.. my aluminum 22-4 horn is different though.
starspike is offline
Old 04-14-2015, 07:57 PM
  #461
"Spanky's Avatar
You are correct 334010 is for a 22-4. Damn. Time for a refund! Lol. Thanks for the help guys. Looks like I need a 1555
"Spanky is offline
Old 04-15-2015, 06:23 AM
  #462
Don't worry about sheets yet. Run what Frank has suggested; make good tire choices and you should be good. adjust your camber depending on traction. Start it about 1.25-1.5
freebird is offline
Old 04-15-2015, 10:11 AM
  #463
Right on, Thanks!
FPMX772 is offline
Old 04-15-2015, 10:23 AM
  #464
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
Thumbs down For the love of GOD
Enough is enough.... Just sell two pack's of Mid Motor wings and be done with it.
Stop making rear motor wing kits and please sell Mid Motor wing kits in a TWO pack.
If we ALL voice our need we might be heard! Calling all MM 22T Body users to use the power of your voice and request Nicley! Please!
Enough is enough TLR this is the #1 thing we ALL need. Stop the insanity !
XXXDad is offline
Old 04-15-2015, 11:14 AM
  #465
TLRacing
Frank Root's Avatar
We would lose money making them. Sorry to inform you, but we cannot make products that we know will lose money.
