TLR 22T 2.0 Stadium Truck >
Old 04-13-2015, 02:29 PM
  #436
Mudcat981's Avatar
Originally Posted by FPMX772
Not sure if anyone has posted this yet, but does anyone know the weight of this truck fully built?
Mine was 1940 with the below equipment.
Savox 1258, Orion Shorty, ORCA ESC, Airtronics 461 reciever, Aluminum Mid Motor Rear Camber Block (no brass). Jconcepts Dirt Webs w/AKA red inserts.
Mudcat981 is offline
Old 04-13-2015, 02:46 PM
  #437
Team Tekin
Randy_Pike's Avatar
Originally Posted by Cojex1
I am building my 2.0 truck and I installed the KO Propo RSx one servo. I followed the chart and used the 1mm spacer. It bumps into the bottom of the bulkhead. I've tried other spacing options and it doesn't seem to help. Any ideas? Do I simply need to use a different servo?
You may need to lightly trip the bulkhead for clearance and or use shorter shims. I'm using a Ko full size servo in my 22SCT(same steering setup) and use .5mm shims.
Are you using the stock servo horn or?
Randy_Pike is offline
Old 04-13-2015, 03:01 PM
  #438
Mine is 1962gm. Race trim MM build with Tekin RSX w/fan; Tekin 8.5; Savox and Futaba 2104 Rcvr. Team EAM 5700 saddles; and painted body. Tires are Jconcepts open cell inserts DD's frt; Goosebumps RR. Ran carpet track Sunday for its maiden outing took fast lap over all but missed TQ. Qual no2 overall finished third. My first 2 wheeler ever. Will probably do some outdoor (weather permitting) this week, and start with the same tire combo but might use DD's on all corners. Waiting on the LHS to get more rims in. I really like this. Its as much fun when I got my 22-4 on its release. Thank you TLR. you make this old fart a happy guy. Oddly enough the truck weight is my birth year.
freebird is offline
Old 04-13-2015, 03:59 PM
  #439
Thanks! I will try the .5 again. Maybe I mistakenly had another 1 mm or something. I am using the stock horn.
Cojex1 is offline
Old 04-13-2015, 05:03 PM
  #440
Has anyone had a change to go head to head with the T5M yet? Curious how this badboy stacks up against that truck
FPMX772 is offline
Old 04-13-2015, 05:31 PM
  #441
I spanked em!!!!!!!
freebird is offline
Old 04-13-2015, 05:33 PM
  #442
Trader Rating: 166 (100%+)
Originally Posted by Frank Root
I run the stock kit setup, only changing 27.5wt in the rear and adding the brass anti-squat block. My 22T 2.0 is DIALED at OCRC. No need for any changes IMO.
My upgraded truck is super good. Actually all of my cars are good. It just depends on mood now shat I will run.
jpcopeland1 is offline
Old 04-14-2015, 03:08 AM
  #443
"Spanky's Avatar
Lots of feedback in the T5M forum about front end parts breaking and steering servo horns breaking.
"Spanky is offline
Old 04-14-2015, 04:55 AM
  #444
starspike's Avatar
I have seen multiple steering horns break.. the losi is always a tank!
starspike is offline
Old 04-14-2015, 10:38 AM
  #445
ProfessorX's Avatar
Trader Rating: 18 (100%+)
Thumbs up
Please don't mention that brand here in my beautiful thread again lol
ProfessorX is offline
Old 04-14-2015, 10:57 AM
  #446
Got mine together the other day, still waiting on some stuff to finish it off.
Got the body mounted, not yet painted, and noticed it hangs low enough compared to the bottom of the chassis that it might drag a bit. Then I noticed on my buddy's 1.0 that he left a good bit of material at the bottom and folded it in and trimmed it to match the contour of the mud guards. Was I supposed to do that too?
Also, can I assume the wing hardware is for the RM? I just used the body pins to hold it on top of the body. Not too sure how much those little triangle pieces are going to support the wing either.
CharlieHo is offline
Old 04-14-2015, 11:08 AM
  #447
68pontiac's Avatar
Check out this post on the TLR blog for a tip on how to better mount the wing in mid-motor.
68pontiac is offline
Old 04-14-2015, 12:48 PM
  #448
Who's running this bad boy at JBRL this weekend?
FPMX772 is offline
Old 04-14-2015, 01:24 PM
  #449
I will be running mine for sure.
hacker07 is offline
Old 04-14-2015, 01:27 PM
  #450
I know Coyote is a pretty tight track, do you know what turn motor you will be running yet?
FPMX772 is offline
