TLR 22T 2.0 Stadium Truck >
Old 04-12-2015, 02:40 PM
  #421
Jack Bonhomme's Avatar
For those drivers who are converting their 1.0 to 2.0 status, and had previously upgraded to the bell cranks steering. The new 2.0 spindles eliminate the steering problem where we had limited equal steering throw in both directions. Previously, I had to have my servo travel cranked up to 150% on my radio to get NEAR full steering lock. Now with the new parts I actually had to REDUCE steering travel down between 75% - 80% travel! I have no problem getting full lock to lock steering. Definitely the new spindles should be at the top of your list for upgrades for the original 22T.
Jack Bonhomme is offline
Old 04-12-2015, 03:15 PM
  #422
Default servo fitment issue
I am building my 2.0 truck and I installed the KO Propo RSx one servo. I followed the chart and used the 1mm spacer. It bumps into the bottom of the bulkhead. I've tried other spacing options and it doesn't seem to help. Any ideas? Do I simply need to use a different servo?
Cojex1 is offline
Old 04-12-2015, 06:11 PM
  #423
walterheard's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Frank Root
I run the stock kit setup, only changing 27.5wt in the rear and adding the brass anti-squat block. My 22T 2.0 is DIALED at OCRC. No need for any changes IMO.
The instructions shows 2mm ballistud on spindle, but the kit setup where it displays the entire car set up shows 1mm on top of spindle. Which one are you using ?
walterheard is offline
Old 04-12-2015, 07:36 PM
  #424
I am building my new 22t 2.0 and I installed the KO Propo RSx one servo. I followed the chart and used the 1mm spacer. It bumps into the bottom of the bulkhead. I've tried other spacing options and it doesn't seem to help. Any ideas? Do I simply need to use a different servo?
Cojex1 is offline
Old 04-12-2015, 08:03 PM
  #425
Is anybody else having issues seeing maifields or roots setups?
Old 04-12-2015, 08:14 PM
  #426
Trader Rating: 36 (100%+)
I'm really considering getting a 2.0, but how do you think it would compare to the 1.0 on an all natural dirt track? The tracks nickname is "the sandbox" and it is actually pretty high traction if you stay out of the fluff that accumulates outside the racing line. Step pins are normally the tire of choice and I actually have been using an ancient pair of losi tires with big pyramid shaped lugs and an x-shaped lug in the center. I run stock truck (13.5) mid motor and mod truck rear motor and didn't really notice a huge difference between the two. The track does get rough and blown-out by the end of the day, we actually stopped running 4 wheel buggy there because of this. Any thoughts would be appreciated.
nitrousdave is offline
Old 04-12-2015, 10:46 PM
  #427
Did you try using no spacers at all? I use Spektrum 6040 servos in all my TLR vehicles with no issues. I'm also using TLR aluminum servo horns on each one.
Old 04-13-2015, 06:36 AM
  #428
I didn't but I can shorter is worse than longer if that makes sense. In other words I tried .5 and it seemed worse. It almost clears at 1 mm
Cojex1 is offline
Old 04-13-2015, 12:23 PM
  #429
ProfessorX's Avatar
Trader Rating: 18 (100%+)
The Dremel is your friend to be scare to use it
ProfessorX is offline
Old 04-13-2015, 12:24 PM
  #430
68pontiac's Avatar
I just wanted to chime in and express how utterly impressed I am with this new truck. I had the original 22T and enjoyed it, but always felt it needed to be driven extremely carefully to work well. (A "driver's car", I'll call it.)
I had high hopes that the 2.0 would make the truck easier to drive and more consistent and I'm pleased that TLR delivered there. I raced my 22T yesterday in it's maiden voyage and not only did I get fastest lap in the class, I TQ'd and I won the main. This truck is just on point. I built rear motor and ran on a low-medium grip indoor track with AKA Chain Links all the way around and I'm confident that I had the only truck out there with forward bite and side bite nearly everywhere on the track. For anybody wondering whether the 2.0 is a big enough improvement over the original it's a resounding yes.
The steering is more aggressive while maintaining balance with the rear. The truck feels infinitely more planted than my old 22T and so much more stable. The only issue I really had with the car was a feeling of on-power push but I'd rather have that than spin out in loose corners. A little heavier on the brake and I had a very driveable setup.
Hats off to TLR - I wholeheartedly agree with their pre-release videos when they said that this is the best 2.0 vehicle to date.
68pontiac is offline
Old 04-13-2015, 12:52 PM
  #431
"Spanky's Avatar
Thanks for the feedback! I'm already excited now I'm beside myself. I can't wait. Should be starting the build tomorrow and really looking forward to returning to stadium truck especially with the 22t 2.0.
"Spanky is offline
Old 04-13-2015, 01:10 PM
  #432
Mudcat981's Avatar
I had the same issue with the alum servo arm hitting the underside of the front bulkhead. I used my xacto knife and just chipped a little off and it was fine. Then I talked to Jason Snyder and he had the same issue and installed the aluminum servo mount part number TLR1550 and it was just enough to move the servo to have clearance without cutting.
BTW they are on back order.
http://www.amain.com/rc-cars/team-lo...lr1550/p212294
Mudcat981 is offline
Old 04-13-2015, 01:35 PM
  #433
ProfessorX's Avatar
I had same issue on my 22 2.0 when I installed the exotek steering rack system I had to Dremel some of the servo horn and some of the spektrum servo to cover now there's no issue works perfectly I didn't have any issues with my 22t2.0 I'm using a hitec full size servo with stock servo mounts loving both of my TLR cars
Old 04-13-2015, 02:03 PM
  #434
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by SoCalMX
Shorty packs. You can only run the full length sticks if built rear motor I believe!?
You can run shorty and full size in RM.
Frank Root is offline
Old 04-13-2015, 02:04 PM
  #435
Not sure if anyone has posted this yet, but does anyone know the weight of this truck fully built?
FPMX772 is offline
