TLR 22T 2.0 Stadium Truck >
Old 04-10-2015, 12:47 PM
  #406
Trader Rating: 166 (100%+)
Was tailking to a friend of mine who runs at oc/rc and he said rete us a spindle mod that gains more steering. Any info about that mod?
jpcopeland1 is offline
Old 04-10-2015, 01:39 PM
  #407
ProfessorX's Avatar
Trader Rating: 18 (100%+)
Originally Posted by hacker07
We will fix the issues and if you contact customer service, they will take care of you. In all fairness, a little outward bubble n the wheel doesnt affect performance at all, yes, it should not be there and we will fix them, and its a bummer, but they work ok. As for the axle, one of mine was bent too, and I am running it and it works great. The axles are different from the 1.0 so MIP doesnt make these yet for what its worth.
As for hop ups, I have to admit, I used alum washers and the alum servo mounts. I think that might be $40. And even those arent needed at all.
Call customer service, they will send you out a whole new pack of 2 of them.
Horizon hobby ??????????
ProfessorX is offline
Old 04-10-2015, 02:01 PM
  #408
Mine came in this morning. Should have it done this weekend depending on how long it takes to complete some work on its sister buggy.
nitro-rob is offline
Old 04-10-2015, 02:25 PM
  #409
68pontiac's Avatar
Team Losi Racing Kits and Rollers (Team Losi Racing products only)
Contact our Race Product Support between 8:30 a.m. and 5 p.m. PST, Monday through Friday at 909.390.9595 or (888) 899-5674 for U.S. residents. Race product support is limited to Team Losi Racing products only.
Source: http://www.tlracing.com/Support/
68pontiac is offline
Old 04-10-2015, 03:10 PM
  #410
We have played with a couple things and there are some ideas out there but nothing has been really settled on for sure. Either version takes some modification and dremeling and wouldnt be for the typical user. The truck is very good as is out of the box with some setup work.
hacker07 is offline
Old 04-11-2015, 11:08 AM
  #411
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
I run the stock kit setup, only changing 27.5wt in the rear and adding the brass anti-squat block. My 22T 2.0 is DIALED at OCRC. No need for any changes IMO.
Frank Root is offline
Old 04-11-2015, 11:18 AM
  #412
Originally Posted by kyosho_utah
Where can I get the mayfield setup from catcus? I tried petitrc and it wasn't showing up.
Seems not to be released yet!
Arn0 is offline
Old 04-11-2015, 12:54 PM
  #413
Mudcat981's Avatar
Had my first run with the 22T last night at Rainman's. "WOW" this truck is awesome. I ran it box stock and it was easy to drive and fast. I even set a best time for myself (one full lap faster)
Saw Jason Snyder and he recommended the 27.5 in the rear, I changed it and the truck was dialed.
BTW Jason put on a clinic with the 22T and his only mod's were the rear shock oil and brass hinge pin brace. He was absolutely dialed and no one was even close to him.
Mudcat981 is offline
Old 04-11-2015, 01:11 PM
  #414
xyzracer's Avatar
Is kit setup rear or mid motor?
xyzracer is offline
Old 04-11-2015, 01:20 PM
  #415
"Spanky's Avatar
Kit setup is for mid, I believe Frank said it's good for rear motor too though but maybe try a green front spring
"Spanky is offline
Old 04-11-2015, 01:40 PM
  #416
Suspended
Default 22 2.0
Anyone drive it and how's the difference of the two
FGomez50 is offline
Old 04-12-2015, 12:02 AM
  #417
what are you guys running for batteries, shorty or full sized packs? I am in the process of building mine I have both types of batteries and want to know what works better for this truck.
Mr. 300 is offline
Old 04-12-2015, 06:25 AM
  #418
Kit goes both ways. Most are building and running Mid, that I've seen or heard.
Ive done the mid build myself and ran on a carpet layout last night for its maiden runs and Holy $#!-. I too change just the rear shock oil on the build to 27.5 and was very surprised out how much steering this has and how much corner speed that can be carried. If the next change is just the brass hinge pin block? Im not sure as to why it might be need or exactly what it will do to enhance the drive; but please Frank explain the big difference of before and after the brass change.
freebird is offline
Old 04-12-2015, 08:27 AM
  #419
TLRacing
Frank Root's Avatar
It'll increase rear grip and stability by have a little more weight bias on the rear.
Old 04-12-2015, 09:25 AM
  #420
SoCalMX's Avatar
Shorty packs. You can only run the full length sticks if built rear motor I believe!?
SoCalMX is offline
