TLR 22T 2.0 Stadium Truck >
Old 04-03-2015, 07:23 AM
  #346
starspike's Avatar
Mine is MM too. I run a D4 17.5 maxzilla with 50 degrees of timing.
starspike is offline
Old 04-03-2015, 07:54 AM
  #347
SoCalMX's Avatar
Originally Posted by ProfessorX
Mines all done
Sweetness...Cant wait to see these running & hear some reviews. I am sure to see one at OCRC today!
SoCalMX is offline
Old 04-03-2015, 08:34 AM
  #348
I will be at OCRC with mine for sure.
hacker07 is offline
Old 04-03-2015, 09:24 AM
  #349
Trader Rating: 166 (100%+)
I don't run the truck, but am just so happy that ST is back at my track. Good luck with the truck. I know it will be good.
jpcopeland1 is offline
Old 04-03-2015, 09:42 AM
  #350
Originally Posted by "Spanky
Maybe cause your from.canada? I ordered 500 bucks woth of stuff and shipped today for 20.49 with kit included
It usually costs a little more, my friend paid $25 shipping for a T5m. I notice it says the box weighed 20lbs which seems high for a four pound truck. I inquired with Amain about this. This truck is a must for me.
nitro-rob is offline
Old 04-03-2015, 10:04 AM
  #351
ProfessorX's Avatar
Trader Rating: 18 (100%+)
Originally Posted by freebird
What size motor did you go with in the mm configuration
ORION vst2 8.5 might go 7.5 and 6.5 too fast for me
ProfessorX is offline
Old 04-03-2015, 10:27 AM
  #352
Mudcat981's Avatar
This is the shipping weight on my order
Weight
8.1 lbs / 3.67 kgs
Mudcat981 is offline
Old 04-03-2015, 11:22 AM
  #353
Trader Rating: 40 (100%+)
Originally Posted by JR V
Almost done with my 22 err XXX-T MF. I want to run 10th truck again, and have three XXX-T MF's sitting here and figured, why not slap something together till the fun money rebuilds and run some vintage Y2kish gear. Wonder if it will keep up with the new age stuff. I do need to get some current tires though. I have lots of step pins, bow ties and ribbed fronts from when we raced in dirt.
Well if truck runs strong here Ill convince myself it is time to run something a bit more modern.
Your tire comment is funny as crap since I had to search like crazy to find new step pins and ribbed fronts since our track is a wet loamy sandy and no other tire works as well on it.
Sandfreak is offline
Old 04-03-2015, 11:25 AM
  #354
ProfessorX's Avatar
Once you get it dialed please share set up. Hell yea OCRC that's where I usually go
Old 04-03-2015, 11:28 AM
  #355
I tried to get back into rc back in 2011 but after building a SC I just couldn't get myself excited so sold everything. I am so glad ST is making a comeback and I can't wait to start assembling my new truck.
Old 04-03-2015, 01:36 PM
  #356
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Kit setup was dialed in at OCRC.... I just like 27.5 in the rear and the brass rear hinge pin mount - only changes.
Frank Root is offline
Old 04-03-2015, 01:42 PM
  #357
68pontiac's Avatar
I've found Jconcepts Goose Bumps to be a good alternative to step pins. Losi Directional Ribs are still relatively easy to find on eBay.
And by the way, where in Southern Oregon are you racing that has a loamy surface?! I'm assuming you must be racing at Klamath Falls? The only other track around here is PBR and it's like racing on a sheet of glass.
68pontiac is offline
  #358
starspike's Avatar
So 30 in the front and 27.5 in the rear.. ill have to see how mine is tonight i did 32.5 front and 30 rear with brass rear hinge pin.. also did you do 1 degree rear anti squat like it says or 2? I normally run two but built it like the kit setup sheet i got off the tlr site and did 1.. i guess ill find out tonight
Old 04-03-2015, 01:46 PM
  #359
Amain updated the shipping and the shipping price is $21 for me now. I just completed the order for mine and will be racing it for the first time on the 19th.
Looking forward to this.
Old 04-03-2015, 03:23 PM
  #360
TLRacing
Frank Root's Avatar
I preferred one degree in testing
