TLR 22T 2.0 Stadium Truck >
Old 02-02-2015, 11:47 PM
  #166
xyzracer's Avatar
Originally Posted by StadiumRC
Is an aluminum idler a necessary upgrade? If running in mid configuration would you run 2 aluminum idlers or just one next to the topshaft? Thanks!
I would think you would want to run a plastic idler next to the top shaft that way you would have metal-plastic-metal-plastic and the plastic gears would act as a "cushion" between the metal gears and to avoid metal to metal contact.
xyzracer is offline
Old 02-03-2015, 02:25 AM
  #167
I'm looking to get the 22T 2.0 what motor would you recommend for mod class ??
Dirtraycer is offline
Old 02-03-2015, 08:06 AM
  #168
Suspended
Trader Rating: 61 (100%+)
Well, trinity makes a 2.5 mod motor now.
Just kidding.
You run whatever you're comfy with. I ordered a 7.5 turn for mod truck.
Socket is offline
Old 02-03-2015, 09:25 AM
  #169
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
If you run on a really high bite track and drive aggressively, landing on throttle when landing jumps etc., it is probably a good idea.
I would also go top shaft, plastic idler, alum idler, plastic diff gear.
7.5T for most and a 6.5T for those who aren't faint of heart
Guess what is in my truck
Frank Root is offline
Old 02-03-2015, 09:28 AM
  #170
Carranza76's Avatar
8.5?
Carranza76 is offline
Old 02-03-2015, 09:35 AM
  #171
TLRacing
Frank Root's Avatar
Originally Posted by Carranza76
8.5?
Maybe for the first half of the trigger pull
Old 02-03-2015, 09:37 AM
  #172
skeasor's Avatar
9T Brushed Modified motor .... 6.5?
skeasor is offline
Old 02-03-2015, 09:41 AM
  #173
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
Lightbulb XXXDad advice
My experience with the Alu idler gear next to the shaft was alott of wear. So as stated above go Plastic then Alu , Plastic then alu.
From this old guy running outdoor loose track I was running a 7.5, found it hard to drive.
So I went to a 10.5 with Boost and Turbo. I like it more because its soft on the bottom but really goes when you apply full throttle.
I have wayyyyy more control. I'm a speed freak but got REAL!
Now High bite is another ballgame, I like 7.5 with zero timing.
XXXDad is offline
Old 02-03-2015, 11:07 AM
  #174
TLRacing
Frank Root's Avatar
Shouldn't have any wear if using some black grease (as recommended). I've run the same top shaft and idler in my RM 22SCT 2.0 (alum v. alum) for well over a year and the anodizing hasn't worn off the parts.... lasts a long time
Old 02-04-2015, 12:37 PM
  #175
JourneyMan's Avatar
Trader Rating: 91 (100%+)
What is the part # for the KYO Gold front spring?
Also... I've been running Dakota's RM setup for a while - wondering if anyone has improved on his RM setup. There any suggested changes?
JourneyMan is offline
Old 02-04-2015, 01:13 PM
  #176
TLRacing
Frank Root's Avatar
http://www.amain.com/kyosho-medium-l...dium-2/p231222
Old 02-04-2015, 03:17 PM
  #177
gticlay's Avatar
Trader Rating: 14 (100%+)
I am really liking the used $35 LRP 6.5 I have in my truck. Never wanting for power.
gticlay is offline
Old 02-04-2015, 04:54 PM
  #178
XXXDad's Avatar
Exclamation Here you go Frank
Yes black grease was used , Here are some Pic. This is a year of Racing with normal maintenance . This is just my experience. Passing along my info just to HELP never bashing TLR> Notice the saw blade effect as a result of Alu. Idler gear in direct contact. Yes I changed the bearing.... but only after I noticed the Bad handling ( hooking when going off throttle)
XXXDad is offline
Old 02-04-2015, 06:13 PM
  #179
Default Jconcepts Body
Does anyone know if the Jconcepts body, part#0226, will fit in both the mid-motor and rear motor configuration? Their website doesn't specify. Thanks.
Jrsandiego is offline
Old 02-05-2015, 09:33 AM
  #180
JourneyMan's Avatar
Frank, I will never complain about the price of a set of TLR LF springs after seeing the KYO cost for one pair.
