TLR 22T 2.0 Stadium Truck >
Old 09-12-2016, 09:56 PM
  #1561
tsair's Avatar
Exotek chassis and 3-gear make the truck pretty amazing.
I have reviews on my blog below. Not only is the Exotek nice to get the battery transverse, but it also makes room to get the ESC down low on the chassis instead of above the battery.
tsair is offline
Old 09-13-2016, 12:02 PM
  #1562
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by DJPod
Are there any aluminum spindles for the 22T 2.0? Since the local track has gone indoor carpet I have been breaking spindles every race day! One wrong move and hitting a wall or post snaps those spindles like nothing!
You'll have to send me a photo, never seen one of those broken.
Frank Root is offline
Old 09-13-2016, 01:55 PM
  #1563
Attached is the image of the broken spindle, I have bought four of these from my LHS in the past month and all have snapped. (all of them are the left spindles, but the wall is on the left side of the track which if hit just wrong, is were they typically break).
Also attached is an image of a temporary fix I made so I could race an A-Main (had no replacements on hand and none left at the LHS) It held up good enough to get 3rd place. Later during some practice with the temp fix spindle installed, the plastic front pivot broke after a bad crash, which I have now replaced with the aluminum pivot.
I have raced this truck for over a year on outdoor dirt tracks and indoor high-bight clay tracks with plenty of crashes and hard hits and only broken a few parts. But when we started racing indoor carpet this last month the spindles have broken at least once every race day.
I am wondering if the LHS got a bad batch of spindles, so I have ordered some online to see if they work better.
Thanks for looking into it.
(PS: looking forward to a 22T 3.0 )
Attached Thumbnails TLR 22T 2.0 Stadium Truck-tlr234044-broken.jpg   TLR 22T 2.0 Stadium Truck-tlr234044-temp-fix.jpg
DJPod is offline
Old 09-13-2016, 02:05 PM
  #1564
TLRacing
Frank Root's Avatar
Yeah, parts break easier when 1) speeds are higher and 2) grip is higher... which you encounter both or carpet. As for any bad batch, I doubt it. This really isn't a part we've ever seen failures with.
Old 09-14-2016, 05:36 AM
  #1565
Trader Rating: 36 (100%+)
Your only choice until someone makes aluminum spindles is to stay away from the walls. I've broken my share of spindles on my 1.0 until I got the aluminum ones, not so many on my 2.0 surprisingly enough. The outside of our carpet track is 2x6's and is very unforgiving if you plow into it at the end of the straight.
nitrousdave is offline
Old 09-15-2016, 06:20 AM
  #1566
ryan432greening's Avatar
The 4mm spindles don't work on the 2.0?
ryan432greening is offline
Old 09-15-2016, 11:12 AM
  #1567
MNiceGuy's Avatar
I have the Exotek and the TLR 3-gear here but I haven't had the chance to mate the two together. Did you have to modify the chassis at all to get that transmission in there?
EDIT: Disregard. I checked out your blog post on the topic. More than enough information there. Nice job on that by the way.
MNiceGuy is offline
Old 09-15-2016, 11:46 AM
  #1568
Are you talking about the 4mm trailing ones for the 22T 1.0? If so, they would probably bolt on but the geometry and therefore handling would be different.
Old 09-15-2016, 07:51 PM
  #1569
Figured so, I just thought it was odd that the spindle was the only part breaking. And perhaps if there was an aluminum spindle the truck would last longer between pit stop repairs.
For now I am going to tone down the speed by dropping to a 13.5T instead of the 9.5T I have been using.
DJPod is offline
Old 09-15-2016, 10:11 PM
  #1570
tsair's Avatar
Thanks! I just wrote up a Top 10 list of 22 "character flaws". Might be interesting, maybe you guys can relate...
tsair is offline
Old 09-16-2016, 05:33 AM
  #1571
A 9.5 on carpet? It must be a blast, but no wonder you are breaking spindles.
Old 09-16-2016, 09:25 AM
  #1572
MNiceGuy's Avatar
I used to go through spindles when I was racing mod (6.5T) SCT on carpet. In my case, the spindle would split right in half at the bearing. I've never busted the trailing arm off.
For what it's worth, every single one of these wrecks I mention I was grateful that the spindle was all that broke. Mod motors and carpet can get things moving very quickly; sometimes too quickly.
MNiceGuy is offline
Old 09-16-2016, 10:26 AM
  #1573
tsair's Avatar
Yeah, I never broke so many things 'til I drove at 702 Raceway. The speeds weren't high, but the plywood jumps and flooring don't give at all compared to dirt which will at least absorb some of the impact energy.
tsair is offline
Old 09-26-2016, 11:58 AM
  #1574
If I'm struggling to find rear grip on a loose dirt outdoor track, should I try removing some antisquat?
Old 09-26-2016, 01:38 PM
  #1575
TLRacing
Frank Root's Avatar
What setup are you running?
