TLR 22T 2.0 Stadium Truck >
Old 07-31-2016, 05:52 PM
  #1516
tsair's Avatar
Originally Posted by r schowengerdt
The 2.0 are a little longer than the first generation
Thanks. I'm guessing they won't work even with shimming?
Frank, any thoughts on the reduced Ackerman you ran on your stock nationals car? I've been thinking about this a LOT, and of all the differences on your car, this seemed to add the most steering to my T2.0, especially mid-corner, and I can't 'splain it.
In simple theoretical terms, less Ackerman should smooth out high-speed steering and more Ackerman should increase low-speed steering.
But... I'm thinking that with the big wide wheels that the stadium truck has, there is less weight transfer to the outside wheel mid-corner (as compared to a buggy), meaning the inside wheel aids in steering quite a bit. With less Ackerman, maybe there is less slip angle on the inside front wheel, allowing the rear slip angles to have higher numbers relative to the front?
Maybe the stock setup has a bit of understeer in it at partial steering angles mid-corner with the stock Ackerman setup, so reducing it balances front and rear a bit? I did notice kit setup had a fair amount of mid-corner understeer.
tsair is offline
Old 07-31-2016, 10:19 PM
  #1517
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by tsair
Anyone know if the 22T aluminum driveshafts fit the 22T 2.0?
They will not.
Frank Root is offline
Old 08-02-2016, 09:10 PM
  #1518
joshualeeduncan's Avatar
Originally Posted by nitrousdave
I tried out the 3 gear trans last weekend in my mod truck and I have to say I like it!!! I could swear I had better traction coming out of the corners and overall the truck seemed like I could drive it a little harder. This is with a 7.0 Fantom on an old school dirt track, plenty of traction though with step pins. I like it so much I'm going to try it in my stock (13.5) truck at the next race. Looking forward to trying one in my indoor (carpet) truck too.
+1, ran on an outdoor track with probably less traction, was very loose and loamy, everyone was running holeshots, carvers, 3d's etc... I should have run RM but decided to mess around with the 3 gear mm for fun. Im not sure if I had better traction compared to 4 gear but it definitely wasn't worse. I was also able to drive the truck much much harder it seemed, could go harder into and out of turns with less spin outs. Also seemed easier to correct if the truck started getting sideways in a turn. In mod class, ill be sticking with the 3 gear from now on.
joshualeeduncan is offline
Old 08-02-2016, 09:12 PM
  #1519
Originally Posted by ryan432greening
And where are these shorter top shaft people are talking about so you don't have to run the nut down so far?
Avid makes it, its an aluminum topshaft that also uses the more common 5.5mm nut on it. http://www.avidrc.com/product/5/acce...cessories.html
Old 08-03-2016, 12:13 AM
  #1520
ProfessorX's Avatar
Trader Rating: 18 (100%+)
MIP top shaft for the win.
ProfessorX is offline
Old 08-03-2016, 12:15 AM
  #1521
ProfessorX's Avatar
Just wondering if this a good way to do the diff rebuild?
https://youtu.be/EToj2yX76NU
Old 08-03-2016, 09:58 AM
  #1522
HBRob's Avatar
Trader Rating: 61 (100%+)
Yes
HBRob is offline
Old 08-03-2016, 03:54 PM
  #1523
tsair's Avatar
AFAIK, they stopped making those. It's been "Out of stock" for more than a year.
tsair is offline
Old 08-03-2016, 05:06 PM
  #1524
DriveItLikeYSIT's Avatar
Trader Rating: 93 (100%+)
I just bought the MIP aluminum topshaft for 22 series. It very similiar to Avids but MIP's uses a 4mm nut
DriveItLikeYSIT is offline
Old 08-10-2016, 01:17 PM
  #1525
Trader Rating: 30 (100%+)
I just scored a deal here on a 22T mm roller. I went with a reedy 13.5 with a 78 spur & 22p. I am running indoor clay track and the issue is after about 7-10 minutes the motor is getting extremely hot around 160 degrees plus. From the losi website it advises using 22p with 78s. Kind of new to the 2wd world but also the timing on the motor was also maxed out at 4o degrees. Any suggestions
ChrisZilla is offline
Old 08-10-2016, 03:25 PM
  #1526
Personally, I don't think ~160 is unreasonable for 7-10 minutes. I push my 13.5 buggy to that temp every round every weekend I race.
If you want to run cooler the first thing to try would be back off the timing 3-5 degrees.
W
Wanderer77 is offline
Old 08-10-2016, 05:13 PM
  #1527
ryan432greening's Avatar
Yeah, +1 I'm always at or slightly above 160 degrees when I'm running 17.5 boosted, and I have a fan attached to my bored out waterfall.
ryan432greening is offline
Old 08-12-2016, 04:48 PM
  #1528
Trader Rating: 32 (100%+)
got a question..bought a used 22t 2.0 and am putting it back to rear motor...on the front of the rear hinge pin blocks it says to use 2 3mm x 12mm screws along with the 2mm x 8mm screw...the screws go through the plastic block...what am i doing wrong...is the plastic block drilled wrong ? any help would be appreciated
thefnshow is offline
Old 08-13-2016, 02:49 AM
  #1529
Blue 31's Avatar
For mid mount the screw passes through the plastic block and screws into the gearbox. For rear mount the screws thread into the plastic block which is a different part. You need to use the plastic block without any degrees marked on it TLR234009. If it has 1,2,2.5 or 3 degrees marked on it the screws will just pass through.
Blue 31 is offline
Old 08-13-2016, 03:41 PM
  #1530
tsair's Avatar
FYI, I just measured my MIP topshaft at 3g and my stock topshaft at 4g.
tsair is offline
