TLR 22T 2.0 Stadium Truck >
Old 01-28-2015, 10:29 AM
  #136
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Looks like we'll have JP Richards running a 22T 2.0 at the JConcepts Winter Nationals at SMAC Track next weekend. Be sure to check it out and root him on!
Frank Root is offline
Old 01-28-2015, 10:47 AM
  #137
Trader Rating: 166 (100%+)
Sweet!! I ran my 1.0 with the longer shocks last night and really liked what it did, was very forgiving where before it would roll over before.
jpcopeland1 is offline
Old 01-28-2015, 11:09 AM
  #138
Originally Posted by shoman24v
I'd much rather buy the Team Losi since it has out of the box capabilities for rear and mid motor config. I'd imagine the T5 would need extra parts that aren't available yet.
And hearing reports that the out of the box setup changes that come with the truck are dialed.
Old 01-28-2015, 11:15 AM
  #139
TLRacing
Frank Root's Avatar
Originally Posted by jpcopeland1
And hearing reports that the out of the box setup changes that come with the truck are dialed. Already a leg up on the AE that will not have a good out of the box setup. Just like Centro B4.2, B5, B5M. Sorry, but AE is hurting right now.
Kit setup is really good, and was finalized at OCRC... so I know it will be good for you
Old 01-28-2015, 11:28 AM
  #140
elikeatts's Avatar
Go JP! He was at the midwinter last year when I was there at CRCRC and he was making his TLR's fly!
elikeatts is offline
Old 01-28-2015, 08:10 PM
  #141
Schs2013's Avatar
There is no st class at my local track so ill be going against 2wd sct's what motor would you guys recommend kv wise? I have a traxxas 3500kv motor i can reuse from my xxx-t.
And gearing. I have never raced at off-road before. Going to give it a try this year.
Schs2013 is offline
Old 01-28-2015, 08:23 PM
  #142
Frank (or anyone who knows),
If I wanted to buy aluminum wheel hexes for the 2.0 would I use TLR2941 for the front and TLR2933 for the rear? Thanks!
StadiumRC is offline
Old 01-28-2015, 08:24 PM
  #143
elikeatts's Avatar
Are you racing stock or modified? The speed passion motors are good and aren't too expensive. Also look at viper. If your just starting off in modified, I wouldn't go lower than a 10.5 to start. Probably a 13.5 would be best, especially if the track is tight. SMC has good motors out now too that are very high quality and low cost, so you could check them out too.
Old 01-28-2015, 08:44 PM
  #144
Schs2013's Avatar
2s only requirement. So i guess modified at this point.
Was thinking of a 10.5 like you said.
Schs2013 is offline
Old 01-28-2015, 09:06 PM
  #145
trutledge83's Avatar
Frank! Please give us the kit set up!
trutledge83 is offline
Old 01-29-2015, 09:59 AM
  #146
TLRacing
Frank Root's Avatar
Front - TLR2941
Rear - TLR2933, TLR2934 (+.75mm), TLR2935 (+1.5mm)
It'll be up next week, or the week after. Still working to create the setup sheet...lol.
Old 01-29-2015, 03:58 PM
  #147
JourneyMan's Avatar
Trader Rating: 91 (100%+)
Anything wrong with the 22T 1.0 titanium turnbuckles? I picked up a couple packages for about $5 a piece and want to use them with HD ball cups.
JourneyMan is offline
Old 01-29-2015, 05:57 PM
  #148
vr6cj's Avatar
Trader Rating: 124 (100%+)
they are smaller in dia. So wont work with hd ball ends or as reads......
"Turnbuckles are 3.5mm in diameter at the threads, which is thicker than the 3mm diameter of the stock turnbuckles for added durability"
vr6cj is offline
Old 01-29-2015, 08:14 PM
  #149
Would I be guessing correct with 30wt all the way around with the 1.5 and 1.6 pistons? With the kit set up.
Old 01-30-2015, 08:32 AM
  #150
JourneyMan's Avatar
That's what I thought... they appeared to be thinner, but I don't have a caliper to check. Is there anything special about the HD cups -- are they a better fit on the ball studs to keep from popping off? Or are they just to support the 3.5mm turnbuckles? I have never broken a 1.0 turnbuckle on ANY of my 22 vehicles. However I have had an issue with the steering links on the 22T and 22SCT popping off. That has since been resolved.
