ELECTRIC STAMPEDE!
Old 09-30-2005, 10:29 PM
Default ELECTRIC STAMPEDE!
im currently running traxxas stampede with a novac super rooster and a 13t orion motor. im wondering what i should run for a batteries. im currently running a 3000 pack but i thought it would have more power and run time?? im thinking of building my own matched pac of 3300. what does anyone think??should i get a 10t and run the 3300 packs that are already made up with connectors and all?? maybe i should go brushless???? any ideas would be helpfull im new to electic trucks.thanks
iceman123 is offline
Old 09-30-2005, 11:05 PM
Team Duratrax's Avatar
If you can afford brushless then go brushless. For good batteries look at www.hyperform-racing.com
They sell GP3300's for $38 including assembly.
Sean
Team Duratrax is offline
Old 09-30-2005, 11:21 PM
thanks man , ive been thinking about it and i think im going to order a brushless kit and batteries on monday.
Old 09-30-2005, 11:41 PM
Which BL system were you looking at?
I suggest the SS5800 as you can pick these up relatively cheap ($160) from Novak's remanufactured shop. Wheelies all day!
Sean
Old 10-03-2005, 08:13 AM
Tech Legend
Cain's Avatar
Trader Rating: 255 (100%+)
You should see a boost in runtime with the brushless system. Only thing is that you may, and this a big may, see a decrease in speed with the novak SS system. The system at times and depending on the application and perform anywhere between a 12 turn or a 19 turn motor. It really depends on the type of motor you are running right now for comparision. If you are just using one of those cheap mods, you will probably see more speed with your brushless.
The nice thing you will see with the brushless is more torque. the SS systems just really have a lot of torque on them, almost too much. guys could easily wheelie there stadium trucks, you should have no problem doing that with your stampede.
If you don't go brushless but want more runs between maintenance, the Orion V2 motors will give you that.
Cain is offline
Old 10-09-2005, 12:23 AM
It's hard to tell exactly how comparably the SS5800 is. Gearing plays a big role to determine it's power to a brushed motor.
Sean
Old 10-09-2005, 02:51 PM
SocalSnakeEyes's Avatar
Make sure to put the Alum. idler gear in when your running that much power.
look here too
SocalSnakeEyes is offline
Old 10-09-2005, 03:58 PM
Platinum_Racing's Avatar
Not to spam, but we also have some cool Stampede parts. Check them out at www.TeamPlatinumRacing.com/StampedeParts.html.
The new ESC Mount will also fit, but it will be a bit off center because the mounting holes are off center on the Stampede chassis.
Platinum_Racing is offline
