rb s5 engine
Old 10-10-2005, 05:35 AM
  #16
macnkitty2002's Avatar
thanks. i did use a hairdryer to heat up the engine a bit, however i don't think that it was as hot as 200f. i will warm it up a little longer next time.
macnkitty2002 is offline
Old 10-10-2005, 05:36 AM
  #17
Davidka's Avatar
Trader Rating: 81 (100%+)
I heated my last engine to 180f and it fired perfectly.
Davidka is offline
Old 10-10-2005, 05:38 AM
  #18
i'm using a Rex cold plug in it. should i change to a hotter plug?
Old 10-10-2005, 05:41 AM
  #19
SpeedBump57's Avatar
Hairdriers don't get very hot. If it is at all possisable buy your self a cheapo heat gun. You should be able to pick one up for about 20 bucks.
SpeedBump57 is offline
Old 10-10-2005, 05:43 AM
  #20
What are the outside temps where you live? What number Rex plug are you using?
