Old 09-27-2005, 09:31 PM   #1
Swanny's Avatar
Default Losi VLA Question
I have just installed the variable length arms on my Losi XXX KE and found the BK2 manual to be a bit vague in the sort of conditions to use the different lengths in.
Can anyone please shed some light on when the long arms are best and when the short arms are best (eg. high traction conditions vs low traction conditions, what handling traits the car exhibits, etc.)? I haven't tried with the long arms yet and I want to get an idea of what I might expect.
XRay T2'009 - Sanwa MT-4 - Futaba BLS551 - Tekin RS - Trinity 13.5
http://www.facebook.com/radioracingcarssa
Swanny is offline   Reply With Quote
Old 09-28-2005, 07:21 AM   #2
Send a message via AIM to TeamRoy
This was copied from Jesse Robbers thread on losibk2.com
"Long Arm set up versus Short Arm setup:
The long arms will be more stable and easier to drive.
Going long in front is more steering on bigger/sweeper turns and usually more on power steering.
Longer rear have more side-bite/less forward bite. So less off power steering but more on power steering.
Usually if have good short arm setup and go to long arms you will need to stiffen up your shocks some or your car will be slapping the ground a lot and also most of time going to longer camber link doesn't hurt also. On tighter tracks I think short arms are better b/c it takes long arms too long to do anything or it happens too late in the turns. Short arms are a lot more responsive, jumps better, car stays flatter, not as good in bumps, and can be looser when initially getting on the gas(for like 1st 1-2 feet)."
TeamRoy is offline   Reply With Quote
Old 09-28-2005, 04:47 PM   #3
Swanny's Avatar
Thanks.
Old 09-29-2005, 04:56 PM   #4
Aaron Waldron's Avatar
That was pretty easy to read for Slobbatech!
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Losi XXX NT Question El Pedro Electric Off-Road 1 04-09-2007 10:27 AM
Losi XXX-S Question Drift_Buggy Electric On-Road 1 03-12-2007 03:14 PM
Losi VLA Question Swanny Australian Racing 3 09-27-2005 09:40 PM
I have a question for you Losi guys! LosiFromHell986 Electric Off-Road 50 05-25-2004 11:22 PM
Question about Losi xxx-spec justin74 Rookie Zone 2 01-05-2003 08:48 AM
