kyosho electric offroad >
Old 11-19-2008, 08:21 PM
  #7561
Casper's Avatar
Trader Rating: 34 (100%+)
They are only sold in a pair.
Casper is offline
Old 11-20-2008, 03:26 AM
  #7562
Registered User
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
I was afraid of that.
I'm in the middle of the FS conversion, but I have a question for you guys. I notice there is some play where the short front dogbone is. Do guys use the small black o-ring to take some of that away? Doesn't say so in the FS instructions. Looks like the bone end can come out and mess up either drive cup.
Thanx
Dasupacat1 is offline
Old 11-21-2008, 02:05 PM
  #7563
I have a zx-5. What do you guys recommend for foam tires?
We have a parking lot at work that a couple of us want to race on.
haulin79 is offline
Old 11-21-2008, 04:23 PM
  #7564
CanyonCarverR1's Avatar
I ran into the exact problem you're talking about with the front dogbone. Destroyed the drive cup. I inserted a couple small peices of foam and haven't had a problem since. I see no reason why o-rings wouldn't work too.
Thanx
CanyonCarverR1 is offline
Old 11-21-2008, 04:27 PM
  #7565
chewiefttc4's Avatar
Trader Rating: 26 (96%+)
I seen one of them fancy new kyosho trucks n I must say it looks very promising
chewiefttc4 is offline
Old 11-21-2008, 04:36 PM
  #7566
Can someone describe the handling difference when switching to the front one-way, other than front brakes.
Old 11-21-2008, 05:11 PM
  #7567
More corner speed and more off power steering and it will pull the car much harder exiting the corner. Can make it a lil tough to drive though
Old 11-21-2008, 07:39 PM
  #7568
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
Give the shaft one way a try, It's simple to change. Feel what it does. I suggest readjusting the endpoints on your brakes till they feel smooth because your gonna lose front braking and the car will be less stable.
The SP seems to steer really well i find and is a nice advantage when you can get away without running a one way. The B44 is good like this as well.
You will also notice the nose will tend to stay up more on big jumps and is harder to get down.
Jason Pelletier is offline
Old 11-21-2008, 08:17 PM
  #7569
I personally don't like oneways. I find that without them you can go much hotter into the corner and transfer more weight to the front tires for more steering. Not to mention more in air control
Old 11-23-2008, 12:59 PM
  #7570
LOSI SCOTT's Avatar
Trader Rating: 70 (99%+)
All of you with a ZX-5 i have a great heat sink with fan for your brushless motor if you are having problems overheating. Check it out PM me if your interested. Thanks
http://www.rctech.net/forum/r-c-item...-sink-fan.html
LOSI SCOTT is offline
Old 11-23-2008, 08:17 PM
  #7571
Trader Rating: 53 (100%+)
whats a good starting point for a 10.5ss with a 76 spur? med-large indoor track lots of infield turns pics can be found here.
www.rcproductdesigns.com/washtenaw_track.htm
nv529 is offline
Old 11-23-2008, 08:29 PM
  #7572
carbon madness's Avatar
If this is for the zx-5, and I had the right info then I would say if you can fit about a 22 to 24 tooth pin as novak says to have around a fdr of 8, and that will get you close. Also for that track I would start off with the 22 as the stright is long, but in the infeild having a little more low end grunt is a nice thing to have (I was at that track once last year, as with the way they had jumps set up you needed some of the low end grunt to clear some of the jumps).
carbon madness is offline
Old 11-23-2008, 08:43 PM
  #7573
Casper's Avatar
In cooler weather or indoor I have run as high as 28/76 with a 10.5. I would start around 25-26 though and temp the motor. I am using SP 10.5 motors.
Casper is offline
Old 11-23-2008, 09:56 PM
  #7574
thanks guys.. this years layout is a lot slower speeds then last years I'm faster with my 17.5 rb5 then with my 7.5 lazer i just can't put the power down and not having a one way input is killing me! hopefully I'll do better next race with a detuned car.
nv529 is offline
Old 11-24-2008, 02:27 AM
  #7575
memyselfandI's Avatar
at the risk of getting shot down here have the rumours of Tebo joining team red true???
memyselfandI is offline
