kyosho electric offroad
#2311
Best off sticking with the Kyosho rims, there are some Tamiya rims with the same size hax but the offset is different.
Here in the UK there are some Fastrax rims knocking around that are spoked but are also slightly different in dimensions.
#2313
Neither would be a mistake, 10 turns seems to be the default choice in a 4wd these days. Try them both and see which you prefer.
#2314
Originally Posted by sosidge
Best off sticking with the Kyosho rims, there are some Tamiya rims with the same size hax but the offset is different......
If you look at the ZX-5 (white) vs. the DF03 wheels, by the look of it, the offset seems the same, but the DF03 rear wheels are wider. Also the older Kyosho ZXR (yellow) is the same offset but is narrower than both the ZX-5(white) and DF03 (Black) rear wheels
#2315
Originally Posted by BringItOn
tony you sending more screws to amain? they are out of stock and looking to buy a kit from them soon with your screws.
If you see something out of stock, I'd call them.
Best regards,
#2316
double post
#2317
Originally Posted by Crim3Wav3
on the KMC conversion...check www.oople.com in the forum section under Kyosho ZX5...ive left some info there about the car.
Any chance a one unit aluminum front tower mount and camber brace may be in the works? I would be extremely interested.
#2318
Question concerning the aluminum shock tower braces....
Is it necessary to have one for the rear shock tower? Yes I have one and just unsure if it is truely needed. I've installed the front hinge pin brace and the front aluminum shock tower mount and installed a T Bone front bumper.
I think I'm pretty much ready to put it on the track I have in it a Novak 6.5 brushless and Peak racing lipo batteries geared 17/76
One thing for sure there isn't alot of room under the body for all the wires and electronics. How are you guys equipment laid out?
James
James
#2321
After the breakage of a homemade CF front shock tower after a full speed (Novak 6.5) collision with a T-maxx, I decided to get a shooters tower as a replacement, well after just a couple of laps I pulled the car off the track and found that the tower had cracked nearly in half in the area of the shock mounting holes. The crash that did that damage was and end over in a medium speed turn.
Just a little warning for the shooters front tower.
#2322
James
James
#2323
Speedy Penguin - I make carbon fiber shock towers as well as other parts for the ZX-5. I have sold an awful lot of shock towers, and I have never heard of one breaking. Somebody please chime in if this is not the case. My towers have a lot more material around the stressed areas. You can take a look at them at A-Main Hobbies. Look in the ZX-5 hop up parts section. The Shooters towers were not very well thought out. It seems like they were made without regard to strength.
#2324
#2325
+1 for Carbon Works Shock towers.
I've even modified mine to allow the body shell to keep the nose attached. It still takes a lot of punishment and hasn't cracked.
