kyosho electric offroad >
Old 04-02-2006, 02:56 PM
  #1501
nutfluff's Avatar
So where's the latest place to buy the front aluminum brace?????
Thanks.
nutfluff is offline
Old 04-02-2006, 03:24 PM
  #1502
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
I haven't seen anybody break a revised stock pivot/gearbox yet...whatever that's worth...
Turbo Joe is offline
Old 04-02-2006, 03:28 PM
  #1503
Turbo Joe's Avatar
Originally Posted by dan_neer78
i thought my zx-5 was invicible . very minimal breakage and i run it hard . i just put those aluminum tower mounts on and now i broke the chassis off right behind the front bulkhead . i am not really mad because it just gave me a reason to get a carbon fiber chassis from carbon works . i still like the car alot . it's very fast and free rolling
You're not going to break a chassis from adding shock tower braces. The tower will snap off WAY before the chassis...BTDT...you must have had a pretty hard hit at just the right angle do do that. It probably would have snapped with whatever brace you used.
Old 04-03-2006, 06:39 AM
  #1504
BenEllis's Avatar
Kyosho America will have aluminum hinge pin braces available soon, hopefully within the next couple of months. The only thing slowing them down is waiting to get the actual product from Kyosho Japan.
BenEllis is offline
Old 04-03-2006, 08:48 AM
  #1505
Ben, any other new pieces besides the braces getting the aluminum treatment? Right now my buggy will be taking a breather til the June 23rd ROAR region 8 regional. I'd like to give it a complete look over and get all new parts on it in time for that race, but if new upgrades come out before then, I'd like to get them as well.
Also, have you run your car with both the universals and dog bones in the rear? Have you noticed any handling differences? I've kinda held off on getting the rear universals since there doesn't seem to be any part #'s out there to rebuild them! Why make the universals rebuildable if you don't sell the axles, bones, and cross pins separate? I really like the construction of them, but Kenshu recently broke an axle on his rear universals... it's no longer usable since there aren't replacement axles. Is Kyosho releasing the parts to the universals any time soon?
Laterilus is offline
Old 04-03-2006, 09:00 AM
  #1506
aaronb73's Avatar
Good question on the universals... I asked that same question a couple of pages back and didn't get a response...
aaronb73 is offline
Old 04-03-2006, 09:35 AM
  #1507
Company Representative
Tres's Avatar
Trader Rating: 14 (100%+)
Laterilus: I tested the 2 back to back.
The stock ones free up the rear of the car a little(mid-corner & exit), which tends to make the car feel as if it has more steering.
At Albion I am always searching to do that. As the track is such high bite.
Otherwise the car is too hook'd and you loose corner speed.
Kinda like the Losi universals vs. CVD's.
Tres is offline
Old 04-03-2006, 11:29 AM
  #1508
BenEllis's Avatar
Laterilus- As Tres said, I like the dog bones alot more, seem to give alot more corner speed on high bite tracks. Once the outdoor season starts I will prob go back to the universals on loose conditions.
Im not sure on a axle rebuild kit, I just ordered several sets, but haven't broken any.
BenEllis is offline
Old 04-03-2006, 02:21 PM
  #1509
Crim3Wav3's Avatar
ok...i answered the dogbones question with a resounding THEY SUCK BALLS!
reason 1: The dogbones get chewed up by the outdrives at both ends due to the fact that the bone floats between the outdrive and axle. Upon full droop (when in the air humping), the outdrive chews the bone. You wont get this with the universals.
Reason 2: no other reason needed.
Crim3Wav3 is offline
Old 04-03-2006, 04:05 PM
  #1510
SpeedyPenguin's Avatar
Ok new question:
How many one way bearings were included in the kit?
I have built my oneway and now I am on the front/center diff and the instructions say part 90(the same one used in the front oneway) but I can't seem to find another.
SpeedyPenguin is offline
Old 04-03-2006, 04:07 PM
  #1511
i believe, someone can correct me, that there are two bearings. so you have to have a solid shaft when running the front oneway.
Chris Jarosz is offline
Old 04-03-2006, 04:11 PM
  #1512
Turbo Joe's Avatar
^^^What he said^^^
You can pick up another set for $15 or less and have both front and middle oneways.
Old 04-03-2006, 04:14 PM
  #1513
joe you gonna be at socal on wednesday? im gonna race 4wheel.
Old 04-03-2006, 06:39 PM
  #1514
Turbo Joe's Avatar
Hmmm....maybe. Wednesday works better for me than Fridays, but I don't know if there's a 4wd class on Wednesdays...and I don't have a 2wd.
Yo Killer...you coming out Wednesday?
Old 04-03-2006, 06:44 PM
  #1515
aaronb73's Avatar
SpeedyPenguin: There's only two one-way bearings in the kit. You can buy them for $10-11 each, part number LA224. You will also need another outdrive for the one-way, part number LA223, $5.
You'd only do this if you want both a front one-way and a one-way on the front input shaft.
aaronb73 is offline
