Old 09-27-2005, 07:16 AM   #1
Default Best brushless motor, for truck??
Looking to put a brushless set up in a mf2, I have herd a lot of people say they are like light switches for the powerband. anyone have any expereince with them, a lot of guys around here have the shoultsie set up. seem like a light swith when i drove one.
D Mac is offline   Reply With Quote
Old 09-27-2005, 08:15 AM   #2
Doughty's Avatar
I use an LRP Sphere and LRP VECTOR in my off-road buggies and the throttle is super smooth through the whole power range, even from a stand still I can make the car cralw along nice and smooth.
I can't see it being any differant in a truck
Chris Doughty - Team Durango - LRP - BETA Tires - Nibbo Design
Doughty is offline   Reply With Quote
Old 09-27-2005, 10:41 AM   #3
I use the Novak SS+ in my XXX-T. I use the S5800 motor and it feels fine. I can also crawl along very smooth or gun it and take off like a bat outtahell. The powerband is very broad just like the LRP. 1024 steps, I believe.
The only drawback is in stock mode with the 5800. It uses the same torque, but limits the RPMs to 24000 or so. The speed control has to constantly cut the off the throttle to keep the RPMs at the 24000 level. This hurts when you hit a big jump and the throttle cuts off for a second. It'll most likely flip. I imagine the 4300 motor may take care of this since it is designed to be comparable to a stock motor anyway.
In full brushless mode, there are no complaints at all.
briansid is offline   Reply With Quote
Old 09-27-2005, 07:23 PM   #4
I know lots of guys love the SS5800 in there AE T4s and Losi's.
They all say they get more runtime on packs, and they like the progammable esc with different profiles.
Novak has a new GTB(Or GT somthing) coming out...Its Brushless and Brushed so you can choose either or. This is especially helpful if Brushless is legal at club races and illegal at big races. Plus if a brushed/brushless motor has somthing wrong with it you can run the other.
The LRP sphere is just like this too.
ZachKipp is offline   Reply With Quote
Old 09-27-2005, 08:22 PM   #5
Doug T's Avatar
Trader Rating: 83 (100%+)
D Mac- What's up Dave...
Remember that you need to tell these guys that it will be running for 20 minute mains, lol. And ask if their systems can run for 20 minutes with no problems (like thermaling). And that you will be using a 8000 Mah Li-Po.
You can drive mine anytime and see how it is.
See you at the track.
For everybody else I run a Schulze U-Force 75 and Plettenberg Extreme motor in a Losi MF1.
Speedzone USA- VSR Racing- M2C Racing- HRP-
Speed RC- The Badlands Supercross- King RC- Phatbottom raceway- S&B raceway
Team Associated
Doug T is offline   Reply With Quote
Old 09-29-2005, 09:53 AM   #6
Thanks Doug T
When you gonna be at the track again?????
talk to you soon
Old 09-30-2005, 05:25 PM   #7
jw92656's Avatar
Smile
Have the GTB in a Losi BK-2, and love it. Bought the Velocity 5.5 to make it a missle. I own two SS5800's system and it just didn't brake very well. GTB is the route I would go. P.S. I had to remove the fan to fit it in the buggy because it started breaking fan blades, and so far it hasn't overheated..
jw92656 is offline   Reply With Quote
Old 09-30-2005, 10:15 PM   #8
Team Duratrax's Avatar
Send a message via MSN to Team Duratrax
Sensorless systems like the Lehner, Feigao etc can be run on more cells, but may not feel as smooth as a sensored system.
If i were to buy a new BL system it would be the Novak GTB. Regardless of its 6 cell limit.
Sean
Team Duratrax is offline   Reply With Quote
Old 10-01-2005, 06:05 AM   #9
Doug T's Avatar
Team Duratrax is correct about the sensorless systems not as smooth on throttle response as the sensored systems. But has anybody with the new novak GTB or LRP Sphere run them for over 20 minutes with a 6000 or 8000 Li-Po battery? I am wondering how they will hold up with the extra run time with a Li-Po battery (heat wise, thermaling, etc)?
Team Associated
Old 10-01-2005, 10:40 AM   #10
Tech Legend
Wild Cherry's Avatar
You don`t really need Ly-Po battery`s...
With a B-4 I can run strong for 18 min with a Neo ! (3300)
Sometimes after practice, I check the clock & I`v been on the driver`s stand over a 1/2 hr. But this is cus of a few crashs ect....
The temperature of my Neo after a full battery pack run, is around 140 degrees , the controller is a bit less around 130 degree.....
If I installed the fan , it would run even cooler....
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 10-01-2005, 12:03 PM   #11
Wild Cherry or Doug would you get more punch from the 3300 versus the lipo?????
Wild Cherry what would you compare it to as far as a brushed motor in terms of turns
thanks
dave mac
Old 10-01-2005, 01:15 PM   #12
Doug T's Avatar
Dave- You will get more overall power out of the Li-Po. I have ran both a 3300 and a Li-Po with the brushless system I have and I know that the Li-Po gives me more punch and top end. That is because the Li-Po is 7.4 V vs. the 3300 that is 7.2 V. If you go witht the 3300's you will probably need 3 of them to get you through the race day (even running one of them twice, 3 Q's + mains). With the Li-Po you will only need one (1st charge with the li-po will get you through 3 Q's then repeak for main). The cost will be about the same for them, 3- 3300's or 1- 8000 2S- Li-Po. I like the Li-Po because I don't have to worry about making run time for the longer mains (20 minute or 30 minute) running a truck. Although you will need a charger that is Li-Po specific, but I know that you don't have any electric gear so you would need to buy a good NiMh battery charger anyways. I really like the Astro Flight 109 for charging Li-Po's. I would say if you run both 3300's and Li-Po's get the ICE charger as it will do both and is a good charger.
Team Associated
Old 10-01-2005, 01:35 PM   #13
Tech Legend
Doug the Neo is a very, very, fast 10 turn !
I don`t know why you would have the need for extra capacity. Already have my arm coming off my shoulder`s ,steering hand & finger`s going so numb I can`t even feel um , ect....
But the LY-PO`s do look interesting....
I myself would`nt even care for the extra capacity compared to being able to reduce weight for a increase in conner speed performance...
There`s other benafits using the Neo & Sphere...
Lighter motor compared to brush, means more sidebite & smoother though the bumps .
Then the brakes, they are unbelievable , way smoother then a brush motor ...
Take my advise , get a Neo brushless as soon as you can .....
George W. Cherry
Old 10-01-2005, 03:33 PM   #14
Default sphere&spektrum
hey guys having problems with my sphere.it sets up fine on the bench.when i put it on the ground and punch it it loses power to the reciever,no steering or throttle
indaway is offline   Reply With Quote
Old 07-26-2006, 07:42 PM   #15
Indaway - I assume your running spektrum... you need to get the optional capacitor for the RX...
I was searching and I had seen it posted for someone else who had the same problem...
Just remember, nothing is free.
ultragraffics is offline   Reply With Quote
FS: MTRONIKS GENESIS TRUCK B/L ESC, FEIGAO 380C-6L MOTOR & REEDY NEO-ONE 4 STAR MOTOR davidrrr R/C Items: For Sale/Trade 5 08-16-2008 03:32 PM
F/S MF2 truck w/CR upgrades, XBR speed control, Fantom brushless motor, Futaba servo DonX1CRT R/C Items: For Sale/Trade 15 07-22-2008 11:19 AM
FS/FT NIB LRP 5.5T Brushless motor/ Castle CM-2080 motor Trade for Newer FUTABA S9451 ffpm46 R/C Items: For Sale/Trade 13 03-31-2008 02:17 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless Motor and ESC combo for 1/10 monster truck vic88my Electric Off-Road 5 10-31-2007 10:40 AM
