Hpi Blitz Brushless Conversion
Needing help, I am converting my 2wd blitz to brushless. Im using the Traxxas 3500 Vilenion system going to be running a 3s lipo and i need to know what spur and pinion to run. i don't want to use the 48 pitch i just don't think that will be strong enough. But i don't know who makes a 32 that will fit. also i want to know what gear ratio i don't want it to be in a wheelie every time i hit the throttle
Maybe Robinson racing.
But if you do blow it out...then swap it with this
http://www.hobbywarehouse.com/RRP7388-HR
Thank you, any idea on what pinion? got a bad habit of ordering the wrong stuff and i don't really want to go through that again.
in my brushless sc10 i use either 16-19t pinion depending on spur size
Page 23 of the Blitz manual has gearing recommendations. The Velineon 3500 motor is comparable to a 10T brushless. Using that information with the manual you're going to want to be around a 21 or 22T pinion if you're using the stock 88T spur.
As stated before, slipper setting and throttle control will be the only thing keeping the front wheels on the ground with 3S.
