Associated b4.2 traction rolling
Ran my buggy on the local track today. It's a short course carpet track. It was rolling over in all the turns. Very aggravating, as it is now, it's bone stock. Suggestions please
Lower your ride height, and slow down a bit.
Maybe change the roll center to a longer link.
Stiffer springs... then you may have to use shock limiters
What tires are being used? Some type of spiked tires? Trimming the outside row of tread sometimes helps. I have traction rolled using slicks on a clay track.
Possibly move shocks to outermost position on suspension arms.
Add more camber.
I have the fronts cambered in 2.5 degrees. the front tires are the original ribbed tires. What kind of tires are best on carpet? Front tire selection seems to be very limited on the fronts
