Like Tree297Likes
Yokomo YZ-2
    Hide Wikipost
Old 08-10-2019, 12:54 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Yokomo YZ-2
Last edit by: mes
Welcome to the YZ2 Wiki!
Setup Sheets can be found here
DT CA DTM parts comparison
YZ2T Tranny Conversion List
YOKZ2-300RFT
YOKZ2-302CT
YOKZ2-302T
YOKZ2-304T
YOKZ2-503I
YOKZ2-0023
CAL3 manual
DTM3 manual
Print Wikipost
Old 10-10-2019, 12:41 PM
  #4516
Tech Legend
Cain's Avatar
Trader Rating: 259 (100%+)
you guys with all the different body experiences, you try the proline elite?
Cain is offline
Old 10-10-2019, 12:48 PM
  #4517
mes
No, don't like the look of it.
mes is offline
Old 10-10-2019, 02:25 PM
  #4518
I have been running the elite for roughly a year now. It's a pretty stable/neutral feeling body, similar to the stock F2 the DTM2 came with, but nowhere near the rear end grip the P2 develops. I like it because it sort of evens out the steering aggression whilst not overloading the rear.
Cain and Tremor24 like this.
mtbwrench is offline
Old 10-11-2019, 02:22 AM
  #4519
Proline elite and JC S2 is almost the same body.
These are the most neutral bodies you can get. No steering , or rear end downforce.
On rough bumpy tracks, these bodies do not push the car down to bottom out.
These two have also the hihgest top speed and jump the longest.
The JC F2 and original Yok body have more downforce in the rear and the original slightly more steering.
I use the original body on the stock car on bumpy astro. Cause the speed is not as high as at mod, so bumping out
is not a problem.
And on the modified car I use the F2 on bumpy astro.
On dirt I use the JC Speed body. Highedt downforce of all bodies, still enough steering. Look atvthe Worlds this year.
Many used this body.
smrcboy is offline
Old 10-11-2019, 10:44 AM
  #4520
mes
Today's test runs on greasy astro with a rearward biased car surprised me. As it was, I preferred the F2 with the light front because it provided more off-power steering than the P2K. As the track dried off a bit, I reinstalled the steel front bulkhead and moved the battery forward, and it was time to shine for the P2K again.
mes is offline
Old 10-13-2019, 02:08 PM
  #4521
lexusbest's Avatar
Does anyone know if there is something happening with the kit? My LHS can't provide me a date because it is out of stock with no entry date
lexusbest is offline
Old 10-13-2019, 03:05 PM
  #4522
DirkW's Avatar
Which kit exactly? The CAL3 and DTM3 are new, so what should happen to them?
DirkW is offline
Old 10-13-2019, 05:40 PM
  #4523
Thereís a CAL3 for sale here on the forum: Yokomo yz2 cal3 NIB
Amain has the DTM3 in stock for online orders
https://www.amainhobbies.com/yokomo-...z2dtm3/p978924
xenon55 is offline
Old 10-13-2019, 09:34 PM
  #4524
lexusbest's Avatar
Oops sry, the CAL3. After a new release it's a common procedure to "stop" the production until the issue is fixed. Just wanted to know if you found something weird
Old 10-13-2019, 09:37 PM
  #4525
lexusbest's Avatar
many thanks but i'm from europe
Old 10-13-2019, 11:04 PM
  #4526
mes
The first batch sold out quickly, AFAIK the next is in production. Tonisport has some stock left.
lexusbest likes this.
mes is offline
Old Yesterday, 04:59 AM
  #4527
Ok. Iím using the mobile site, so I donít see user location.
xenon55 is offline
Old Yesterday, 11:51 AM
  #4528
DirkW's Avatar
Wouldn't make a difference, since he has not entered his location.
DirkW is offline
