Yokomo YZ-2
#4366
This one?. That spacer goes between the rear brace and the suspension mount. Raising the trans also raises the rear brace that bolts to the suspension mount, so the spacer fills the gap
#4367
Ok, That makes sense. I had picture the rear spacer going under the RR block.
#4370
Now I'm unsure if the truck chassis really is longer, but he has all that space up front, a full size servo, a large ESC with a cap sandwiched in between and room to spare before the battery. My buggy has room to spare before the battery but no real estate in front of the servo, and despite running a half size servo and a small esc and receiver in comparison to his, its stacked all against each other.
#4371
It is the truck bulkhead, as it's quite a bit beefier and direct swap for the buggy part (with minor trimming to the body). On the current setup sheets they are all running the truck steering rack with the short bell cranks which could account for the extra perceived space in front of the servo. I tried running this steering setup this past weekend, and with the .5 offset truck steering blocks it really does change the steering feel and I like it.
#4372
The team is currently testing a new transmission that looks like the truck trans (split case). With this new trans, you have the ability to raise the diff (similar to the truck or 4wd). Since we can't do that with the current production trans, we use the shim kit and raise the entire trans, not just the diff, 2mm. It's not the exact same thing, but it's as close as you can get with the parts available.
#4373
#4374
Tech Legend
#4377
#4378
There are 2 versions of steering bell cranks.
#Z2-201CSB carpet verion, normal lenght pivots
#Z2-201DSB dirt version, +2mm pivots
now you can mix them, take dirt akermann plate and carpet pivots, so you do not need to put 2mm under ball studs to have
the same geometrie.
Thats all.
So nothing really new up in the front of the car, except they put the link from the servo tie rod now on the pivots, to make an even faster steering.
In the rear its a brand new lay down carpet tranny, nothing to do with the truck one, except raising the diff without spacers.
The Eos track was big, without very tight turns, so they used the 0,5mm akermann plates. On tight tracks the old carpet ones will surely be used.
the same geometrie.
Thats all.
#4379
The truck bell cranks are part of # Z2-200NT, which also includes the center link.
#4380
