Like Tree277Likes
Yokomo YZ-2
    Hide Wikipost
Old 01-31-2019, 11:39 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Yokomo YZ-2
Last edit by: Cain
Welcome to the YZ2 Wiki!
Setup Sheets can be found here
DT CA DTM parts comparison
YZ2T Tranny Conversion List
YOKZ2-300RFT
YOKZ2-302CT
YOKZ2-302T
YOKZ2-304T
YOKZ2-503I
YOKZ2-0023
Print Wikipost
Old 02-07-2019, 07:40 AM
  #4351
Super Moderator
Trader Rating: 21 (100%+)
Originally Posted by HotRod127 View Post
what all parts would i need to make this work on my car? thanks for the help
YOKZ2-300RFT
YOKZ2-302CT
YOKZ2-302T
YOKZ2-304T
YOKZ2-503I
You also need to either drill the kit chassis or replace it with the revised one.
For the record, I haven't run this trans myself. I have friends who have, but most of them are using the standard trans raised 2mm, which is the setup that Ryan and Ryan have been running.
Bob Barry is offline
Old 02-07-2019, 12:03 PM
  #4352
Originally Posted by Bob Barry View Post
YOKZ2-300RFT
YOKZ2-302CT
YOKZ2-302T
YOKZ2-304T
YOKZ2-503I
You can not run the Truck trans in the buggy!!!!
The rear arms will hit the spur gear. Thats why the new car wont come as quick. The rear arms have to be altered, like the truck ones.
smrcboy is offline
Old 02-07-2019, 02:15 PM
  #4353
Super Moderator
yes you can. you need to shave the arm. I forgot that part. Like I said, I never tried this myself, so I missed that step.
Cain likes this.
Old 02-12-2019, 03:50 AM
  #4354
antlockyer's Avatar
Hi all, new to off road, been racing onroad 12th and TC for a couple of years. There is a second hand YZ2 available with 3 gear transmission, gear diff, gull wing arms etc.
I'll be driving on an outdoor Astro track. Is the CAL2 going to be that much better for me as a newbie or will the hopped up YZ2 be ok? the only thing drawing me to the older car other than the price is it also comes with an upright gear housing and ball diff in case I need those for low grip if I travel to a different track.
Thanks in advance
antlockyer is offline
Old 02-12-2019, 06:26 AM
  #4355
Thanks in advance
It sounds to me like the YZ2 your looking it is a CA? I think the original yz2 had the flat front arms, 4 gear, and a gear diff, and the CA had the gull arms, 3 gear and gear diff. I think the easiest way to tell might be the rear arms, if they have s4 stamped in them ( I think that was a ca change too), and if it has the gull wing shock tower up front, which I think you are supposed to use if using the gull arms.
Either way, as a newbie, I don't think you will see much difference, if a hopped up yz2, yz2 ca, or a cal2. Eventually you will want the ca or cal2, but you could also upgrade the parts along the way I think.
{tpc} is offline
Old 02-12-2019, 06:48 AM
  #4356
antlockyer's Avatar
Cool thank you. I've said I'll take it. I'll see how much use it gets and if I'm any good
Very excited I've not driven a buggy since the 80s
Old Yesterday, 02:32 PM
  #4357
Default Knightmare day
Well we just got eos carpet so the grip has jumped up a lot....never had a problem before but today did 2 sets of slipper pads had to use the original 3 pad set from the old yz2 due to not having any more spurs....
so had a bad set of runs....
anyway been trying 2 gears in the diff high capacity 6k not sure if I like it car used to be in the top finals now it feels like a bag of crap...used long wheelbase and moved the shims on the wishbone tried rp dirt orange and green but car donít feel as good basically has lee martins daun and not sure but now car wouldnít not steer how I like it
sort of wondering if itís all down to running 2 gears and 6 k...
what does everyone think and what does it do by running 2 gears over 4...
thanks
Quietman is offline
Old Yesterday, 03:37 PM
  #4358
Trader Rating: 71 (100%+)
From the recent pics I have seen that go along with the setup sheets found on petit, that they are running the LD trans from the truck. Maifield 2019 CRCRC for example shows no rear chassis weight that comes standard with the DTM2, using steel RF block, truck steering linkage, etc. I can't make out if there are new rear arms or whether they are dremeled for clearance (or does raising the LD trans 2mm negate the need to dremel the arms?)
I think at this point the setups found online need to be taken with a grain of salt because they aren't the same cars as most of us are running.
negatv1 is offline
Old Yesterday, 04:54 PM
  #4359
They are using a new laydown transmission case. It is Not the truck transmission. An easy way to tell is look at the waterfall holes on the chassis, it is mounted forward of the truck holes.
Rhett McNair is offline
Old Yesterday, 08:42 PM
  #4360
Ok, yep just noticed the waterfall mounting holes. As for raising the transmission, are they using a 2mm spacer under the RF block as well as the RR block? Seems like raising the rear block only would change the anti squat.
negatv1 is offline
Old Today, 01:06 AM
  #4361
Will27's Avatar
I don't think they are raising the suspension mounts, this would change the rear roll centre dramatically.
With the new type gearbox I don't think they are raising it, I suspect they are using the diff cams to raise the diff up 2mm inside the gearbox and the setup sheet is showing how to achieve similar settings with the old gearbox / motor plate / rear tower. The aim is to adjust the diff height.
Will27 is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
