17.5 stock buggy is death slow...
so I have a weird situation...I have a brand new dex210 that I have a phantom racing apex 17.5t motor in and a turnigy trackstar 120a esc. I have the esc set to default settings with no boost for blinky mode and stock racing, but my car is seriously about 3/4 the speed of all the other stock buggies on the track. it does the same thing when I toss in my Speed Passions StockClubRace esc...timing on the motor is set to around 40 and I have a 69t spur/35t pinion setup. Any suggestions are greatly appreciated!
Make sure your motor is turning the correct direction, it is possible with the 210.
In other words, building the gearbox with the motor plate on the wrong side. Also try dropping your gearing 2 or 3 teeth.
I have the same setup and had the same issue. It was the bearings that was dragging my buggy down. I run rm4. I took all of the bearings out and de-greased them. Make sure that the diff isnt shimmed too tight and that your gearcase screws arent too tight. It really frees up the gearbox alot. Also you can over drive the esc endpoint to 110% but that didnt do much.
I'm wondering if you aren't about 10 teeth over geared.
What is your motor temp after a run?
Super Moderator
Trader Rating: 31 (100%+)
You're over geared, unless the track is huge, or that motor is known for insane amounts of torque. How hot is that motor? I was gearing my D4 at 55 degrees of timing in a B5RM and mid motor (Have same trans ratio as your durango car) at 29:69 in the MM, and 32:69 in the rear motor.
In 17.5, 1 tooth on the pinion can make all the difference.
