1/5 (scale) Revo DBXL
#62
You can use both as I do to get more. The thickest you can add Ofna Diff Lock Lube isn't thick enough to get what these big tires and brushless power do to these diffs. and once they break loose it is over. your stuck. with the spring and adding aluminum washers on each of the spring to get even more grip. It acts like a locker that gives under a hard landing or pinch in some how. I want it to grip and rip and to break loose before something breaks. You can't do that with oil.
#63
Hey guys the spring works great and it is meant mostly for for loose tracks and off-road stuff. sand, mud, rocks and hill climbing. It's not for every buddy but it is for a large number of rc people that have Axial and traxxas products ect... If you have 4 spider gears in your diff cup then this isn't going to work.
#64
The tranny is a E-Revo and the Motor mount is a HPI Vorza and the motor is a Leopard 4074 2200kv running SMC 2s 60-120c 9400Mah lipos in series to get 4s. It has a 22'' wheel base and is 18'' wide and weigh is at 18 pounds loaded.
#65
I bought the springs at home Depot years ago in a variety pack had 2 of the same springs and I think 4 different types.
#66
