how to make 2x 3s into a 6s battery >
Old 11-09-2014, 09:50 AM
Default how to make 2x 3s into a 6s battery
Doing some research for a friend who is getting a 6s arrma Keaton ....he has a couple of 5000mah 20c 3s batteries and I know you can turn them into 6s but not sure if they have to be 3s1p or 3s2p....and what if anything else will be needed
happyhour82 is offline
Old 11-09-2014, 10:00 AM
wire them up like a saddle pack
jnyrcr is offline
Old 11-09-2014, 10:05 AM
Old 11-09-2014, 10:34 AM
rcjunky1's Avatar
The + on the ESC goes to the + on one battery, the - on the ESC goes on the - of the second battery, and the + and - on the batteries get connected. Look up a dean's series adapter for a picture
rcjunky1 is offline
Old 11-09-2014, 10:48 AM
You should never run in series batteries that have different cycle history.
They must be new and always used as a set
ebay007 is offline
Old 11-09-2014, 10:58 AM
RC Juice's Avatar
Trader Rating: 140 (100%+)
Are they hardcase or soft case? If they are soft case with the wires built-in (or hardcase with built in wires for that matter) just get series connector.
RC Juice is offline
Old 11-09-2014, 12:05 PM
They must be identical batteries and then just plug them with this conector:
For Traxxas :
http://www.ebay.com/itm/Traxxas-TRX-...item3f37e1be9b
For Deans;
http://www.ebay.com/itm/Dean-T-Plug-...item3a7ceb49c1
http://www.ebay.com/itm/Dean-T-Plug-...item233df7e251
But it is to Over Kill your Kyosho Inferno MP9E.
I would put then in Parallel with parallel plug and you could increase twice the running time 10.000 mah 20C 3S
SJGSM is offline
Old 11-09-2014, 12:41 PM
rcjunky1's Avatar
He wants series for 6s, 3s will be super slow
rcjunky1 is offline
Old 11-09-2014, 09:30 PM
ekt
ekt's Avatar
The ARRMA Kraton is already wired to run 2x3s packs in series using t-plugs. If running a single 6s pack, there is a bridging plug provided.
ekt is offline
Old 01-24-2015, 09:25 AM
Cracked Shaft's Avatar
Any recommendations on which battery to use for
4s setup and 6s setup?
Cracked Shaft is offline
