Toro 1900kv 6-pole motor >
Old 10-28-2014, 08:53 AM
Default Toro 1900kv 6-pole motor
Who has tried one of these in a Truggy? How did it do? I just assembled a Tekno ET48 and I need something lower in kv than the 2200 that's in it now. I don't need sensored but in the future if I ever put an rx8 in it it would be nice to have it there. It's just under half price of a tekin 1700 truggy motor and I'd like to save a buck or two if possible.
http://pages.ebay.com/link/?nav=item...d=221463875183
Exojoe is offline
Old 10-28-2014, 09:08 AM
Ho1aw's Avatar
If you choose a 6 pole motor why not choose Tenshock. They are the 1st one who make 6 pole motor, very professional.
I have this one:
http://www.ebay.com/itm/Tenshock-1-8...item46177f6ff7
The rotor is wrapped with kevlar and balanced.Very stable.
Ho1aw is offline
Old 10-28-2014, 09:10 AM
tc5 man's Avatar
6 pole like that hang on if your racing !
tc5 man is offline
I've heard good things about the TenShock motors. But a 2400kv is going the wrong way for me. I need 1900 or even a 1700.
Exojoe is offline
Old 10-28-2014, 09:26 AM
Super Moderator
DRTMI's Avatar
Trader Rating: 27 (100%+)
Hobby King has a 1/8 1900 motor for around $60 and SMC has one for around $70
DRTMI is offline
Old 10-28-2014, 09:44 AM
I'm newcomer.what's different from 4 pole and 6pole?
magenepaile is offline
Old 10-28-2014, 09:50 AM
found this tenshock 1850KV on ebay. So long as you guys say the durability is there Ihave no problem ordering this dude today.
http://www.ebay.com/itm/Tenshock-1-8...item46177f6ed7
Exojoe is offline
Old 10-29-2014, 10:23 AM
Ho1aw's Avatar
I have their 4 pole SC401v2 and also 802v2.
Go ahead.
You will feel more sensitive in acceleration!
The power is released smoothly...
Just image, when the motor runs a lap. The power is separated to 6 points than to 4 points.The power is getting more smooth.
Ho1aw is offline
Old 10-29-2014, 10:41 AM
RC*PHREAK's Avatar
Trader Rating: 128 (100%+)
i would not run the buggy motor in a truggy. i couldn't keep the buggy motor cool in a buggy. if you're set on a 6 pole, go for the x802L, which has a longer can (more torque for the heavier truggy).
RC*PHREAK is offline
Old 10-29-2014, 02:32 PM
Not dead set on a 6-pole but it seems like a stronger option. Chances are I'll end up with a Tekin 1700 truggy motor. I can get a Poseidon 1700kv motor but its 106mm long and would require me to relocate the esc not to mention I just don't trust two little 3mm screws holding all that motor in place considering the flat landings that happen when you overshoot a landing ramp.
Exojoe is offline
Old 10-29-2014, 02:42 PM
I have the tenshock 6 pole, it's complete overkill on top of the fact it will swell your batterys
Rickybob is offline
Old 10-30-2014, 01:43 AM
RC*PHREAK's Avatar
if you have the money for the tekin truggy motor, go with that. if you want to save a few bucks, go with the hobbywing 4274 1800kv motor. both are plug and play and will serve you well. why roll the dice with the 6-pole thing? again, i speak from experience. i've tried 2 tenshock 6-poles in 1/8 buggy and i couldn't keep them cool (burned one up). putting one in a truggy (even though i know the tekno truggy is lighter than most truggies), is just asking for issues.
the problem is the tenshock rotors just aren't big enough. yeah, we've all heard that more poles=more torque, and maybe for equal rotor size, that's true, but the tenshock rotors are much smaller (diameter wise) than the tekin or hobbywing motors so torque is down which makes them run hotter for the same speed as the tekin/hobbywings.
Old 10-30-2014, 07:25 AM
Ho1aw's Avatar
No. Tenshock rotor is nearly to 21mm. it should be bigger than Tekin/hobbywing. Tekin i remember is about 18.5mm. Just measured my rotor 35mm in length(it is my X802V2.If take X802LV2 should be longer that this).Tekin is 30mm.That means Tenshock has more power than tekin.
I think the reason why you get hot is the power is too big, the tires have not enough grip.This gets much hot.Maybe you should change the set of pinions, adjust the shock and tires.
Ho1aw is offline
Old 10-30-2014, 08:41 AM
TZ
A friend of mine runs a tenshock in his truggy, no issues, no overheating.
TZ is offline
Old 10-30-2014, 09:33 AM
RC*PHREAK's Avatar
i'd love to see a pic with the calipers on the rotor. i took apart my X802 after it burned up and the rotor was 15mm in diameter. it was a V1 though.
