Clean & Restore Vintage rubber tires from the early 90's. >
Old 10-27-2014, 06:45 PM
Jack302's Avatar
Trader Rating: 22 (100%+)
Questions?? Clean & Restore Vintage rubber tires from the early 90's.
What should i use to restore vintage tires for a JRX2 /JRXT from the early 90's?
I did a google search and see people saying silicon oil or or dilute glycerine.
Will WD40 or Armor All dry them out more?
Any tips would be appreciated.
Jack302 is offline
Old 10-27-2014, 07:03 PM
littlevette's Avatar
i cleaned some super hard team associated rc10t stock tires with white moldy residue recently. it took a while, but it worked. i used some hot water mixed with simple green. i would let them soak in the bath for a good while, til the hot water started turning a bit coldish. i then took them out and soaked the tires with simple green and hit them with a finger nail brush. little by little they started looking new again. you could also use oxy clean instead of simple green. once they dried they looked new. i stored them in a plastic bag afterwards.
littlevette is offline
Old 10-28-2014, 05:57 PM
Jack302's Avatar
Hot water with simple green i will try that.
Jack302 is offline
Old 10-28-2014, 08:03 PM
corn_bread's Avatar
Trader Rating: 40 (100%+)
belt conditioner from your auto part store. spray and let them sit. use a tooth brush to really massage it in. works great as a traction compound too
corn_bread is offline
Old 10-29-2014, 10:31 AM
Scrubb's Avatar
I used Hy-traction Juice Red (R/C tire sauce) on some vintage tires and they turned out great.
Scrubb is offline
Old 11-15-2014, 07:17 PM
Jack302's Avatar
Thank you...
Jack302 is offline
Old 11-15-2014, 08:07 PM
simple green up here to..
coolair is offline
Old 03-05-2015, 04:02 PM
Jack302's Avatar
Simple Green is better than water and dish soap to clean tires?
Jack302 is offline
