Ways to slow top speed...
I have a rc8.2e rtr buggy that I use as a basher. 2000kv motor mamba monster 2 esc. Other than changing the gearing or putting a limited on the controller. How can I slow down my car some more? I'm just a basher. The faster it goes the bigger I try to jump it ect. So I break parts. I just want the top speed to be slower. Not limit he power with punch control or anything like that.
well changing the motor with a lower kv will do it but that more expensive then lowering the pinion teeth or getting a bigger spur. also you can lower the battery from 4s to 3s all of this will bring you to a lower speed.
Originally Posted by alberta guy
(Post 13595406)
easy cheap fix you can put something behind your trigger/ or the trigger itself... like tape and wrap it around till you get it where you want it. |
Turn down the EPA on the radio.
(Post 13595406)
I'd start with stop pinning the throttle. ;) |
Originally Posted by ThoughtCriminal
(Post 13595591)
This is the first post I've read that someone wants to go slower. :lol:
If you don't want to change anything then throttle control is the answer.
Just lower your end points for throttle
Originally Posted by exheliguy
(Post 13596023)
*shakes head*.......leaves
(Post 13595733)
Like I said. I'm nothing but a basher. My buggy comes everywhere with me. Saturday night for instance we were drunk and all my friends have rc's also. We built a ramp that made by buggy go about 10 feet in the air to flat ground. When er eryone else had slower machines and we're going around 5 feet. Lol
