INTECH Racing ER14
#271
Hello everybody. I was just wondering if anyone has tried fitting any other bodies? I have 2 er14's but only 1 body. Any info would be appreciated
#272
It is possible but the topdecks are mounted very high in the car so other bodies do need alot of cutting to fit. You would also need to cut the chassis and fit chassis side rails from that manufacturer as the Intech is the only car I can think of that has completely straight sides. My car with XB4 bodyshell and side rails.
#273
Thanks conrad. That xb4 body looks sharp on there. Looks like not much cutting required either, except for some on the front. Thank you for the info. I'll check into that
#274
It is a tight fit, there is only a couple of mm between the shocks and body at the rear. The front body post was moved back about 10mm if memory serves me to get the shell low enough.
I know someone who used B64 side rails and body, it turned out well although the side rails on the B64 are shaped so some more detailed cutting of the chassis is required.
#275
What year xb4 siderails did you use? Not sure if there's much difference in them though
#276
I used the '18 model year. They are the same shape, the mounting holes are in different positions is all. I drilled my own holes for mounting so it doesn't really matter which you use.
