17.5 a bit slow, mod setup suggestions? >
Old 10-01-2014, 01:28 PM
  #16
SkiRideDrive's Avatar
Alright ordered up some parts. Hopefully I can try them out next week.
SkiRideDrive is offline
Old 10-03-2014, 09:06 AM
  #17
turbo2cam's Avatar
Trader Rating: 16 (100%+)
If you got the trackstar ESC, be aware that you need the trackstar programming box also. The hobbywing box won't work with the trackstar. But it will work with the hobbyking unit.
turbo2cam is offline
Old 10-03-2014, 09:25 AM
  #18
Tech Legend
Cain's Avatar
Trader Rating: 252 (100%+)
can you flash the HW programmer to trackstar firmware? That probably would make it trackstar specific at that point, but good to know none the less.
Cain is offline
Old 10-03-2014, 12:27 PM
  #19
turbo2cam's Avatar
Good question, I have not tried that...might be a viable solution.
Old 10-04-2014, 02:24 PM
  #20
Davidka's Avatar
Trader Rating: 77 (100%+)
Originally Posted by Cpt.America View Post
If you have been a 17.5 guy for a while, and want to bump up to try mod.. I would suggest a 13.5 first... or maybe a 10.5. Going right to an 8 may be a handfull.
This is good advice. When you go even to a 13.5, its a whole different world. I race stock and mod on the same day (10.5 in mod) and it's very different.
Originally Posted by SkiRideDrive View Post
To each their own I suppose. I'm just looking to have some more fun. I take motorcycle racing much more seriously. This is more of a side hobby.
Consider thinking of them as being closer to the same. If you changed something dramatically on your bike, enough that it took you a while before you were able to ride as well as before, you'd get frustrated, no?
If you buy a 13.5 motor and a speed control with dynamic timing capabilities you can start a little faster and then add timing/gearing changes to make it fly later. If you go straight to the big motor it may be a while before you can drive it well again.
Davidka is offline
Old 10-05-2014, 11:05 PM
  #21
I can confirm this... dissapointing. I installex the motor n esc tonight and just ran it down the street on stock esc settings. Wow... so much more motor than stock 17.5. Should be entertaining at the track.
Old 10-05-2014, 11:07 PM
  #22
I am going to look into this. As of right now the box wont even recognize the esc.
Old 10-06-2014, 07:57 AM
  #23
Tech Legend
Cain's Avatar
yeah, that is pretty much what we Speed Passion Guys did when the speed passion branded programmer, the one that looked the same as the HW one went out of stock or was hard to get.
I actually like the feel of the HW one as it felt more sturdy.
Cain is offline
