PR Racing SB401 4wd Off Road Buggy >
Like Tree89Likes
Old 01-11-2019, 12:58 PM
  #766
zx12r785's Avatar
I dont think many use rctech as much as years past, Facebook is definitely more active than rc tech...
And I do not have a 97mm...I'm sure the stores should very soon with them getting the new v3 parts, so I'm sure they will also stock up on stuff they are out of
bring it on likes this.
zx12r785 is offline
Old 01-11-2019, 09:00 PM
  #767
zx12r785's Avatar
First picture of PR racings 401R-T
zx12r785 is offline
Old 01-13-2019, 09:12 PM
  #768
Trader Rating: 124 (100%+)
Probably a long shot but anyone off loading a type r yet?
zx12r785 likes this.
ROSCOE is offline
Old 01-13-2019, 09:51 PM
  #769
zx12r785's Avatar
I doubt it, but might wanna ask in the Facebook groups
zx12r785 is offline
Old 01-18-2019, 04:03 PM
  #770
Does anyone have a part # for the front sway bar mount that attaches to the front diff case with the 2 little set screws
Never mind, got it
bring it on and zx12r785 like this.
rippen is offline
Old 02-03-2019, 05:52 AM
  #771
Hi.
i have some questions about flat landing.
My car sb401 is setup with orange yatabe springs rear and yatabe purpel frront springs.
I have some trouble that the car bounces on flat landings.
I have tried 300-550 oil in the shocks and 1,6-1.8 pistons. Full droop or with 4mm spacer inside of shock.
If i downside the jump i have no trouble.
Is my springs to stiff so that the car rebound to quickly and bounces?
or do you have another solution. seen som setup with harder springs and some with softer.
also seen some with weights in the rear.
I have no weights.
i saw that someone mentioned Facebook groups.
Is there some good ones for sb401 or some with racing advice?
rippen likes this.
qvick is offline
Old 02-03-2019, 07:42 AM
  #772
Originally Posted by qvick View Post
Hi.
I have no weights.
There is alot of info on PR's facebook page
rippen is offline
Old 02-10-2019, 04:11 PM
  #773
Well it's time to lighten out the SB401 type-R, just ordered titanium screws, ball studs and turnbuckles from T-works
rippen is offline
Old 02-10-2019, 11:58 PM
  #774
zx12r785's Avatar
get ya the aluminum dog bones for the rear arms and the front center bone...the front center is actually 1mm shorter than the standard steel one but theres plenty length still.....we used to make 75mm front bones for the LW but they got discontinued, but I'm actually gonna see if we can get them going again....but using the e others I could already see some more acceleration since they are half the weight of the stock ones
bring it on and rippen like this.
zx12r785 is offline
Old 02-11-2019, 12:01 AM
  #775
zx12r785's Avatar
Hi.
I have no weights.
the older shocks have that problem without actually switching to the new type R shocks which I highly suggest..the quickest and cheapest fix is to glue a blank or any piston in the bottom of the barrel...you'll think I'm crazy but it's a known fix for the old shocks....the rear hop on flat landings is very hard to get to go away without that piston glued in the bottom of the barrel..
zx12r785 is offline
Old 02-11-2019, 01:14 PM
  #776
Bones are next
rippen is offline
