Old 09-19-2005, 02:49 PM   #16
ive used automotive fan belt dressing..
it worked ok, but promoted tire wear
MManson is offline   Reply With Quote
Old 09-19-2005, 09:01 PM   #17
SlobbaTech's Avatar
If the track is soooo wet that the tires cake up bad and car comes off track with mud caked in tires then like no tire dope will do much and any tire should work that can hold onto some mud. I think for track it sounds like you run on you should try buggy grip or zip free if it's wet/tacky, if it's dry and dusty then don't use anything or maybe just motor spray. Usually the tire dopes don't work well, usually are worse, if there's a dust layer on top of the dirt in race line.
SlobbaTech is offline   Reply With Quote
Old 09-20-2005, 01:34 AM   #18
Aaron Waldron's Avatar
Hode on man!
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 09-20-2005, 10:37 AM   #19
Tech Legend
Wild Cherry's Avatar
Sounds like perfect conditions for slicks....
When a track is so wet as this, I would at least try the slicks & put the diesel on....
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 09-20-2005, 03:12 PM   #20
Mason's Avatar
Originally Posted by ahsikes
I have been away from offroad for a while. An offroad track opened in my area for the first time in a while and the tire of choice is some pin.
I was wondering what is available to prevent the tires from packing up with clay?
I used to use simple green, greased lightning, and others, but just wanted to know what the latest/greatest is.
Aaron, I'm assuming this is the Hobbytown?world?whatever? outdoor track up there.. Simple Green to clean and store, and if you need more for the race try some buggy grip. Also an important thing to remember is that the foam determines how much the carcus will deform and trap material. A stiffer foam will keep the pins opened up more.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 09-21-2005, 05:49 AM   #21
memyselfandI's Avatar
What is Simple Green??? where do you get it from????
Carisma Racing Australia
Modelflight.com.au
Team AKA
Ryper Hobbies
memyselfandI is offline   Reply With Quote
Old 09-21-2005, 06:51 AM   #22
Simple green is a cleaning fluid. You can pick it up at grocery stores.
It's simple and it's green.
Homer Allman is offline   Reply With Quote
New Tire Sauce EAMotorsports Electric On-Road 45 05-15-2007 08:53 PM
tire sauce TRF_StEvE Australian Racing 2 08-26-2005 06:28 PM
Paragon Ground Effects Tire Sauce Woes Mr. McGoo Electric On-Road 7 08-17-2005 10:52 PM
Stickum tire sauce, the best tire sauce for any tire any surface adootindotin Electric On-Road 86 12-16-2004 03:00 PM
Simple ? - What tire sauce at TamiyaUSA? Rob Mincey Electric On-Road 5 08-03-2004 11:46 PM
