Old 01-20-2006, 04:26 PM   #211
Moderator
Packfan's Avatar
Trader Rating: 115 (100%+)
Originally Posted by riverrevo
Hey Packerfan your rig looks killer, but the PROLINE 23MM ADAPTERS ARE SUSPECT IMHO, get the Dace. I never finished a race without breaking an axel with them, but that was on a Revo and thats an enferrior(sp?) car anyways-LOL
These are the 23mm truggy adapters. I ran the 23mm adapters on my Revo all last year and didnt have any trouble. Savage had a good point now that I think about it and that is the possible steering loss.
Could not do this without my sponsors: OBR/Turtle Racing Core Team, Oneill Brothers Racing, Turtle Racing Products, Axis RC, Detroit Performance RC, Booster Pipes, Ronshop Racing, MIP, Undertaker Custom Paints, Hilantronics, Hitec, Mattox Designs, Team Chase, Phatdad RC, Bodies by Hill, RedXRC
Packfan is offline   Reply With Quote
Old 01-20-2006, 05:07 PM   #212
wild gopher's Avatar
Trader Rating: 39 (100%+)
thanks again for the feedback everyone. I think im gonna try out the nubs and see what they do. I might also borrow a set of crime fighters from a friend and see what those do as well.
Steve, I will stop by your shop next week on my lunchbreak.
RCtech - Filling me with adult drama since 2003
wild gopher is offline   Reply With Quote
Old 01-20-2006, 08:17 PM   #213
SavageSYNTH25's Avatar
Send a message via AIM to SavageSYNTH25
Good move Packfan, I'd try somthing a bit smaller, because that's a fairly small track. Try the stock wheel/tire combo, of the HPI Nubz. The truggy looks great though, good luck with it!
No problem Wayne, any time. BTW, the Jammin buggy I bought from ya is still running strong!!!!!
SavageSYNTH25 is offline   Reply With Quote
Old 01-20-2006, 10:09 PM   #214
WheelNut's Avatar
Send a message via MSN to WheelNut
Packfan- I would definately recommend narrowing that thing down! You wont get any steering out of it with that kind of width. Its just going to generally handle really weird being that wide. The dace adaptors would probably work well with narrowing, or Wabash wheels. Did you paint that body? It looks really good!
WheelNut is offline   Reply With Quote
Old 01-20-2006, 10:16 PM   #215
Moderator
Packfan's Avatar
I just sold the wheels and tires in the for sale forum. I have a set of Wabash 40 series with the 1/2" offset and that really narrowed it down. I also have the stock Crime Fighters.
The body was painted by Full Throttle Racing.
Thanks for the help
We got MORE SNOW TONIGHT C'mon April!!!!
Old 01-21-2006, 11:05 AM   #216
Ah, so you are the one who bought it.....nice. I drove alot of different buggies and that one was by far the best. I almost bought another one the other day but went with the truggy instead.
Old 01-21-2006, 08:13 PM   #217
Nice!
Have fun with the truggy, Jammin really did something special with this one!!!
Old 01-22-2006, 03:34 AM   #218
richb3's Avatar
Send a message via AIM to richb3
Post
Some action shots from today (first one has a new hellfire in the background)
One
Two
Three
Four
richb3 is offline   Reply With Quote
Old 01-22-2006, 10:36 AM   #219
TKO Development
Check out the link above. These 23mm hubs keep the stock truggy width when you use 23mm wheels, and will bolt right on to the CRT.
Not that you would want to use 40 series, but.........
Old 01-23-2006, 08:17 PM   #220
ETRacer's Avatar
Ok dose any one have any input on this?, here is my original email to Jammin that has so far gone with no response...
I have just finished building my new CRT and have a
question about the front shocks.
In the instruction sheet it states 37.5mm for distance
on the front shocks. there is no way the front shocks
can be this long. I tried 30mm on the shocks and found
that if the lower mount is in the center hole on the
arm the droop will not be able to reach full
extention. also at 30mm the bottom spring retainer
will bottom aganst the shock bootie before the chasis
ever touches the ground.
I have seen your posted setup sheets claiming 26-29mm
of distance on the front shocks, also that you are
running in the upper row of holes in the front tower,
in this location the ammount of front suspention droop
would not be much at all.
Did i get an incorrect set of shock shafts with my kit
or is there something i am missing?
Dose any one else have this issue? or am i the only one...thanks
ETRacer is offline   Reply With Quote
Old 01-23-2006, 08:25 PM   #221
Suspended
ntro75's Avatar
My kit will be in soon, I will build the shocks first and let you know what I come up with.I should have it wendsday
ntro75 is offline   Reply With Quote
Old 01-23-2006, 09:13 PM   #222
richb3's Avatar
ETRacer: Your comments piqued my interest (I feel I'd seen them before, but forgot to go check it out when I got the chance. This time I did.
Allright, first I went out and measured everything. I also only show 30mm of length. I have the shocks in the stock upper middle hole, and have it on the inner hole on the bottom. I checked a little bit, and found that my droop screws aren't even functional right now (which i shall immediately fix)
I don't have a problem with the chassis hitting the ground (it does) before everything bottoms out, but I could see it being a possibiliity after I move the shock to the lower position.
I also checked the possibility of OFNA meaning it was 37.5mm from the bottom of the shock body to the mounting hole, but that definitely isn't the case.
However, I also don't think that longer shafts would work because the bodies aren't long enough to accomodate it, so I'd say ofna screwed up a bit.
What it means overall? if you want to run in the top mounting holes, then your droop screws will basically need to be tight enough to cause the arms to be level so you don't reach the end of shock travel. As for up travel, in my case, I don't think this will be a problem.
I doubt you got the wrong shafts, they must have the wrong numbers, or else the entire shock system is messed up.
Hope this helps, let us know what jammin says if they ever reply.
-Rich
Old 01-23-2006, 09:30 PM   #223
Suspended
ntro75's Avatar
So in a nutshell, you all are thinking the shocks are to short in the front? if so by how much are you finding is lacking?
Old 01-23-2006, 09:45 PM   #224
richb3's Avatar
Default Shocks tooooo short??
I don't know about too short. With longer shocks, you'd have longer bodies, then you'd probably have a bottoming problem but not a droop problem. What it means for me in the short run is to go to the bottom row of holes, and be sure the droop screws contact and stop the travel rather than stressing the shock pistons.
Yeah, you could say a bit too short, probably wouldn't be a bad analysis, but I don't think it'll be a major problem.
Old 01-23-2006, 09:55 PM   #225
Suspended
ntro75's Avatar
Thanks for the info!
RC-Area Interview Adam Drake 2007 ROAR Gas Offroad National Champion kúv!n Nitro Off-Road 0 07-12-2007 03:31 AM
Roar 2007 USA Off Road Nationals Champion crowned! 7.5man Canadian R/C Scene 0 07-01-2007 06:39 PM
2005 Australia IC On-road National Championships Boz Australian Racing 67 11-04-2005 04:54 AM
Malaysian National Championship (EP) 2005 Jamal D'Maz Malaysian R/C Racers 360 10-26-2005 03:22 AM
