need to know answer
Old 08-31-2014, 08:02 PM
Default need to know answer
What is a sensorless rtr 3600kv motor equal to in brushless turns motor? 1/10 scale 540.
Keith B is offline
Old 08-31-2014, 10:38 PM
Yosh70's Avatar
Trader Rating: 17 (100%+)
Heres a chart that you can look at....took about 10 seconds to find via Google.
http://www.teamnovak.com/products/br...spec_chart.htm
Yosh70 is offline
Old 08-31-2014, 10:45 PM
84 GT 5.0's Avatar
Trader Rating: 26 (96%+)
8.5-10.5
84 GT 5.0 is offline
Old 08-31-2014, 11:00 PM
OK anyone else. Thanks for those two. Saw the Switchbacks and I like its looks, thought maybe I could put it in 2 wheel stock.
Keith B is offline
Old 09-01-2014, 12:08 AM
Teufel Racing's Avatar
Trader Rating: 29 (100%+)
Just did a quick google search for your question,
Speed passion had a 11.5 turn/3600kv listed
Trinity had their Maxzilla 17.5turn/3600kv listed
That's a pretty good range in turns for sure. I would have said maybe somewhere between a 10.5 and 13.5, but after the search, I don't think I'd be 100% right.
Teufel Racing is offline
Old 09-01-2014, 05:27 AM
Super Moderator
Might help to provide more info on the motor you have, brand, what rtr it came with, etc.
Can't go only by kv rating, as torque is equally important as rpm in determining power. If the motor is a 4 pole for example the kv comparison can be misleading. Kv comparisons are most useful when comparing otherwise similar motors.
Dave H is offline
Old 09-01-2014, 07:05 AM
Its a leopard branded 3600kv. I am under the impression if you race 17.5 13.5 etc the kv rated motor has to be equivalent. It is in a 2wd buggy. Distributed through Racers Edge
Keith B is offline
Old 09-01-2014, 09:31 AM
Super Moderator
Don't believe it is equivalent. A 13.5 or 17.5 class needs just that, a 13.5 or 17.5, that provides equivalence, or at least as close as is realistic while allowing a variety of manufacturers.
However, most any decent track will allow a new racer to get their feet wet with what they have, until they have a chance to get suitable equipment. Suggest a discussion with the race director, should be able to work something out.
Also ask around for the more experienced guys, I've loaned stuff out or sold usable items inexpensively many times to help someone out. I'm hardly the only one, seen it happen many times.
Dave H is offline
