TQ 13 gauge wire on 1/8 Buggy???
I have a Losi 8ight E 3.0 that I am wanting to rewire mostly for cosmetic reasons. I have heard people say good things about TQ wires so I ordered the 5 wire set of TQ 13 gauge wire. It looks a lot thinner than what is in there now. Is anyone running this wire on an 1/8 scale buggy? I will be running 4s on a Tekin RX8 esc and Tekin R8 2050kv.
TQ wire has a thinner silicone coating than most other wires, so it looks smaller but seems to perform similarly to 12 gauge. Since their only other option is 10 gauge I would say you should be fine. However running 10 gauge won't hurt at all either.
OK. Thanks guys. I'll get to work getting it done tonight.
Thanks guys! I love how easy this wire was to work with. If it holds up, which from all accounts it should, I can see myself using it in all my cars.
Done and done...
Done and done...
How does this wire compare to Deans 12ga Wet Noodle?
About identical. The lower the number the greater the a strand count usually which means more flexible and easy to work with. The key is to use the bare minimum amount of solder when you Pre-Tin and when you solder up points so that only the exposed portion of the lead will lose flexibility.
Actually, the gauge number only refers to the diameter of the wire. Higher strand count is better, but usually found in higher quality wires (like we get from TQ, Deans, Novak and other RC oriented companies).
I've wanted to place an order for custom colored wires last year and spoke with several manufacturers and found the exact same "brand name" stuff RC companies sell as their own, but the minimum order was too costly for me so I decided to hold off. Red, Black, Yellow, Orange and Blue are great but if you enjoy wiring up your cars and having it match a custom scheme, having colored wire to go with it all is a nice option.
