Need Some Help [ Noob Questions]
#16
i have this charger http://www3.towerhobbies.com/cgi-bin...?&I=LXDVNT&P=7 and a 2s 4000 mah lipo. i plug everything in put it on 3 amps and it gives me the error code [ Voltage Difference among cells is too large ( >300mV) any help thanks? btw this is my 1st time charging this battery. ran my RC today and now when i try to charge it this happens, and yes my RC car has a lipo cut off
#17
Make sure you have a good connection with your power and balance plug. I've seen that same error message on my charger and that's what fixed it, I just unplugged it and looked at my connector (XT60) and noticed the male and female were fitting loosely. I adjusted the fit and then it has worked fine since.
