Xray XB8E thread
#706
What's the chances of getting an optional plastic spur for XB8e '16?.... just puttin it out there.
#707
Has anyone tried running the active diff at the front? How did you find it and what surface were you using it on?
#710
Ok guys, Thanks.
#711
XB8 808 original
I was trying to convert my original XB8 X-ray into eletric haven't found a conversion kit. Only option I found was to buy the 808E parts any ideas from fellow fans of Xray buggy's?
#712
Any suggestions on getting a smaller turning circle? I'm running the car mainly on a 1/10 track
#713
I have it and my track is bumpy and hard pack with lots of turns. I love the active diff in the front I like it some much will try to active diff in the center which they sell for this car. The front active diff makes the car turn better and handle better.
#714
If it's '14 or '15 there is a list here, but it's costly
http://www.neobuggy.net/2015/01/23/x...nversion-list/
If your talking about the old model XB8 then good luck
Drop front ride height, what's your current ride height? Bring front hinge pins all the way in. Check end points. That's a good starting point.
#715
What year XB8?...
I'll try dropping the ride height - currently it's at the bones level height. The upper hinge is all the way in but the bottom hinge is not so I might bring that in as well to try reduce the track width.
#717
Hey guys,
I just got my XB8e running and whet to grab a pinion for it...is this one of the Mod 1 deals? My pinion (15T) was very loud and just didn't seem to line up 100%. Thanks in advance for the help.
#719
Yes it's Mod 1, the metal spur gear will make it sound more noisy then maybe you are used to, a brand new pinion should help it be a little less noisy.
#720
Sounds good and thanks for the quick info. I did the nitro buggy thing a decade ago so noise was not really a factor, but now with these electric ones and metal/metal, it was a little strange (I am used to metal/plastic with the 10th scale). I know i have a non-mod1 pinion on there now so that is probably where all the noise is coming from. New pinions are on order.
