TLR 22SCT 2.0 Race Kit: 1/10 2WD SCT thread >
Like Tree6Likes
Old 03-29-2017, 08:34 AM
  #2671
Originally Posted by bmag5000 View Post
I'll wait for the 4.0 since the buggy just came out. So it might be another year or so before the 4.0 SCT comes out.
The 4.0 buggy has the parts that they used on the SCT 3.0 and only thing different form the buggy to the SCT is a laydown transmission. Laydowns are not needed in SCT cause the weight bias is already close. So I don't see a new SCT for a while now. 2 years min. IMO
fantomdude is offline
Old 03-29-2017, 08:42 AM
  #2672
OK so ill get the 3.0 SCT next year then.
bmag5000 is offline
Old 03-29-2017, 12:19 PM
  #2673
Hey guys I know I cant be the only one with a 2.0 SCT, post up!
No you are not alone. Still driving my 2.0 as a rear motor truck does better on my medium grip clay track. I'm going to be trying my truck without the sway bars on our new layout to see how it drives. I love this truck! SOOOOO much steering and so fun to drive. I'm also switching from 20K diff oil in the gear diff to 3k. With the 20K, the truck had absolutely no rotation at all. 3K should solve that problem.
MaX-D is offline
Old 03-29-2017, 01:02 PM
  #2674
xyzracer's Avatar
Which gear diff? Rtr or the new 22 one?
xyzracer is offline
Old 03-29-2017, 01:09 PM
  #2675
RTR. I put the orange Kyosho o-rings with AE green slime in it. I've had absolutely zero leaks. It's been great
MaX-D is offline
Old 04-02-2017, 11:28 PM
  #2676
Default Body Mounting
Is anyone using a different body mount setup?
After running traxxas and Tekno, I'm not happy with just the clips as they break through to easily and adding any tape or washer makes it almost impossible to put the clips through the holes. I've even drilled the hole in the posts out bigger.
I see a Pro Line Extended body mount kit ( 6306-00 ) with their secure-lock screw on caps, but it seems to be discontinued.
Anything better out there that I am missing?
Thanks in advance,
Shanon
shanondink is offline
Old 04-04-2017, 08:05 AM
  #2677
made the podium with my 2.0 saturday,got 3rd place
bmag5000 is offline
Old 04-04-2017, 09:21 AM
  #2678
NICE! Good job.
MaX-D is offline
Old 04-10-2017, 12:23 AM
  #2679
bubbaslash's Avatar
My youngest boy bought a very nice 2.0 with Exotek chassis and almost all the available upgrades. It's dialed and he loves it. Weight is all where it needs to be, and the modular design allows the whole front end to come off with 6 screws for access to the steering. I may go to a gear diff whenever the stocker needs rebuilt. Trying to decide whether to use an RTR diff with the o-ring swap, a Serpent diff, or the new TLR planetary diff. I could have sworn that I read on here that someone had a fitment issue with the new diff in either a 1.0 or 2.0, but I can't seem to find it.
bubbaslash is offline
Old 04-10-2017, 04:21 AM
  #2680
My RTR diff has been flawless with the Kyosho o-ring swap. No problems at all.
MaX-D is offline
Old 04-10-2017, 08:18 AM
  #2681
Trader Rating: 40 (100%+)
I have the new all aluminum gear diff in my sct 2.0. I haven't ran it enough to comment on performance or durability, but the fittment is fine. No issuesat all.
lstmadness is offline
Old 04-11-2017, 08:23 AM
  #2682
Nice. Just curious rear motor or mid motor?
jiml is offline
Old 04-11-2017, 09:44 AM
  #2683
xyzracer's Avatar
Pretty sure hes running rear motor, i think he posted a pic a page or 2 back. I do know he races dirt oval tho.
Fwiw i still run mine rear motor on indoor clay offroad at rain mans in bakersfield. To this day i still run faster lap times with this truck compared to my sc5m which is pretty much dialed in with 3 gear, brass block, similar running gear, etc.
xyzracer is offline
Old 04-11-2017, 10:26 AM
  #2684
Good info. Thanks.
jiml is offline
Old 04-12-2017, 01:44 AM
  #2685
bubbaslash's Avatar
Originally Posted by Callaway View Post
Maybe there's not much new to post because the truck has been out a few years, pretty much anything you can do to it or want to know has already begun discussed in this thread. Certainly ask if you have a question about something, but I wouldn't expect much buzz or gratuitous updates to be going on in this thread... all that is happening in the 3.0 thread!
I do have a few questions. What bellcrank, servo mounts and servo horn did you use on your 2.0 build? Exotek claims that their horn won't clear one screw on their nose plate. Is the kickup angle 25 like the stock chassis? Also, I'm a little surprised that your 3.0 is better on carpet than the 2.0 with the semi-laydown 3-gear. Anything in particular that could account for that? On indoor clay the 3.0 rocks.
