Team Associated B44.3 Factory Team Thread
#617
Has anyone driven one of these yet? Wondering how it compares to the other buggies out there.
#618
It's really just the b44.2 with some weight rearranged. There are plenty of drivers on the b44.2 and even this thread that have already submitted some input on the new layout and how it drives. Seems the result is: it handles as well or better than the old b44.2, but can be suited for different track conditions with the optional shorty setup and included center diff.
#619
While I haven't driven a 44.3 yet (mine shipped today), my understanding from the guys that tested and driven quite a bit is that is handles equal or better, is more nimble, jumps better, and the center diff is a huge asset. Sounds like you can punch it even more than previous B44's.
#620
Hi all,,finished my 44.3 and had a couple of minor problems.
Shims too large for outdrive bearings= get the dremmel to work,,
and a couple of other minor issues,,it'll be good to hear if anyone else had issues with advice to solve,,
Running gear diffs and gear center diff with shorty config,,
Thanks.
Thanks.
#626
Most definitely worth converting, no slop and risk of popped ballcup is greatly reduced. You will need the ballcups and (12) 8mm B5 ballstuds. If you have the JC aluminum rack, replace (2) 8mm studs with (2) 10mm studs. If you use the rear CF hub tower, replace (2) 8mm studs with (2) 6mm studs. you will need 3mm nuts but for the steering hubs you can either tap the 4-40 nuts with 3mm tap or Dremel down a 3mm nut to fit. Tapping would be easier. I would suggest getting two packs of the B5 ballcups to avoid using the "bent" ones or you can use those on the rear hub tower. your choice.
#628
Can someone explain why everyone is so excited that this buggy now comes with gear diffs?!?! In my opinion, a ball diff is WAY easier to adjust and tune. I can loosen or tighten it in a minute or two. With gear diffs, you have to remove it and change the gear oil. Plus, if the 1/10 gear diffs are like those in my 1/8 scale, I had to rebuild them every two weeks. I've got about 4 weeks on my SC10 ball diff and it's still perfect.
What am I missing?
BTW: I ordered mine today and also ordered ball diffs for the front and rear
What am I missing?
#630
What am I missing?
What am I missing?
