2014 1:10 ELECTRIC OFF-ROAD ROAR NATIONALS > 2014 1:10 ELECTRIC OFF-ROAD ROAR NATIONALS
Old 08-12-2014, 12:14 PM
  #31
Originally Posted by JP.R View Post
Will there be any "sneak peaks" of the new layout for the ROAR Nationals next?
We should have something up for everyone by Monday so stay tuned...
Space Coast R/C is offline
Old 08-14-2014, 06:11 AM
  #32
PW
PW's Avatar
Originally Posted by Gitsum View Post
I hope a new layout is being put in with all the fees the attending racers have to pay. $85 to enter, $10 for Wednesday practice, $25-$160 for a pit space, $??? Tires for the event. I assume there will be a lot of angry racers if they show up to a busted up track with wrecked jumps and huge cracks.
I stopped by the track yesterday and the Bobcat was already delivered, so something is happening
PW is offline
Old 08-15-2014, 03:54 PM
  #33
Super Moderator
Kraig's Avatar
Trader Rating: 73 (100%+)
Default FYI
ROAR Rules update
August 14, 2014
Rule 8.2.3
All chassis (including optional/aftermarket) in all electric classes (except those specifically noted) MUST accept batteries up to the maximum dimensions allowed for its application. Chassis must have at least 1 standard configuration (standard configuration to be saddle or stick pack) to fit a battery of maximum dimensions for that class or it will not be considered legal, and the racer will be disqualified. Foam blocks/spacers are permitted to help secure any size battery in its position. Electronics may also be located within the battery area when "shorty" or smaller legal batteries are used, provided that "permanent" mounts for the aforementioned don't preclude the installation of full size battery or saddle pack of maximum dimensions. The only exception is 1/8 off-road where it's common to use two battery packs to achieve the maximum 4S configuration, or to use a single 4S battery, which has a different specification. Only under these circumstances will the fitting of either configuration be considered legal, but the production chassis must still conform to batteries of the maximum allowable dimensions. Should a question arise as to whether the chassis will accept a full size pack it will be up to the racer to prove that the chassis meets all requirements.
Kraig is offline
Old 08-16-2014, 06:00 AM
  #34
memyselfandI's Avatar
Originally Posted by Kraig View Post
ROAR Rules update
August 14, 2014
Rule 8.2.3
what does that even mean????
a car that has been wired up in a shorty configuration ei Ryan Maitfield's 22-4 is illegal????
memyselfandI is offline
Old 08-16-2014, 06:36 AM
  #35
Robby368's Avatar
Trader Rating: 14 (100%+)
For the spec stock tires, how will tech know they're softs or not? Before I mount tires, I scrub them down with simple green and the paint dot comes right off. I'm buying all my tires from the track, but just want to make sure I don't have issues in tech.
Robby368 is offline
Old 08-16-2014, 08:38 AM
  #36
Corally USA's Avatar
Corally USA is offline
Old 08-17-2014, 08:17 AM
  #37
Super Moderator
Kraig's Avatar
I think a lot of people are asking that same question.
Kraig is offline
Old 08-17-2014, 08:40 AM
  #38
aeRayls's Avatar
It means that you can now use whatever size battery you want. As an example: you can now place your esc/rx in the battery tray of a T4 and use a shorty pack.
Before, the rule stated you had to be able fit a "full size" pack in the car at all times regardless. Now, as long as the car is manufactured to fit a full size pack that's all that is required.
aeRayls is offline
Old 08-17-2014, 07:36 PM
  #39
Any pics of the layout yet?
Gitsum is offline
Old 08-17-2014, 07:46 PM
  #40
seth556's Avatar
Trader Rating: 42 (100%+)
Here's a picture I found from the other day on Facebook.
Attached Thumbnails 2014 1:10 ELECTRIC OFF-ROAD ROAR NATIONALS-10580892_307739926065794_5914723584040231479_o.jpg
seth556 is offline
Old 08-18-2014, 06:31 AM
  #41
��I found the jumps ��
Gitsum is offline
Old 08-18-2014, 11:37 AM
  #42
MPrincip's Avatar
Default Jumps
��I'm looking for the jumps ��
The jumps are medium sized. There's a triple jump but until the traction comes up, you will only be able to Double Single.
Hope this helps. Only 2 more days till Practice!
MPrincip is offline
Old 08-18-2014, 07:31 PM
  #43
seth556's Avatar
https://www.facebook.com/SuperiorHob.../?l=5d161d3d50
Here's a new photo
seth556 is offline
Old 08-18-2014, 08:06 PM
  #44
Tech Legend
Wild Cherry's Avatar
Default track layout
First Class
Wild Cherry is offline
Old 08-19-2014, 09:42 AM
  #45
Super Moderator
Kraig's Avatar
left to right or right to left? Sorry, things like that to me are not always obvious in pictures.
Kraig is offline
