Mugen MBX-7T Eco
Mugen MBX-7T Eco
Figured I would start a x7T eco thread for setups and stuff I will post my setup later today. But my first impressions of this truggy are great, it steers terrifically jumps great and has a very planted feel to it. My only very small issue is my rear side bite in corners is not were I want it to be so once I get that perfect I'll be a very happy guy. The truggy is top notch mugen quality even though some guys have had issues with the kingpin pillow balls breaking, I have not had this issue personally. I'm sure mugen is taking care of it and they are aware of the issue and anyone who has had this issue should contact mugen USA and they will gladly replace the part for you. So guys let's get some info generating on here and find what is working and what's not working. My first input is the diffs I started at 10 front / 10 center / 7 rear and it was ok good starting point but I'm going to try 7 front / 15 center / 5 rear cause I want a little more off power steering and as I stated earlier the rear is a little loose in the corner. On the shocks I'm using the 5 hole straight pistons (0543) I believe is the part number I'm using 700 cst front / 650 cst rear with 7.5 front springs and 8.0 rear springs my Ackerman I have the plate reversed 2nd hole forward and everything else is stock position at this time I will keep it updated. So if anyone has anything to add let's hear it
Yes
There is already a thread started http://www.rctech.net/forum/electric...-electric.html
