Team Associated T5M Discussion
#4036
Where is your rear camber link set? I am running the aluminium B6 hubs with the V2 axle on mine. But my camber link is set to the inner hole with 3 holes up on the hub, and center hole on tower. On fresh track rebuilds I lower the inner ballstud all the way down, no washers to tighten up the rear entering a corner. Once the track gets a traction compound grove to it, I start getting a push and add 1mm under the inner ball stud to loosen the rear end up until it feels right. Hope this helps, it is on clay indoor track also. Love my XT6.
#4037
Try taking out the shims under the ball stud at the tower 1st, 1mm at time. Like I said on a fresh track rebuild I am running 0 spacers under the tower ball stud to tighten up the rear end of my XT6. I do not know the differences between the 5 series aluminium hubs and the 6 series aluminium hubs, but we are using the same hole and same amount of spacers on the hub.
#4040
Trader Rating: 89 (100%+)
SLRC Chassis
I purchased a roller and it has this chassis installed . It appears it might be a lighter option? Is there a link somebody knows of to this company to get more info on the chassis. Is it better to run the stock chassis if I plan to run open or mod motor on astro turf ? I would think I might want the weight of the stock chassis to have a lower LCG? Any info helps, advanced thanks !
#4042
#4043
thanks for the help I will give that a try
#4044
Been running laydown on my XT6. Anybody running stand up on clay?
#4045
Front shocks I am running white springs, 35#, and 1.6 pistons. With gray spring I have a really bad push.
Jmoney I had the 3 gear stand up in my XT6 for its very 1st 2 batt packs only because I was waiting on all the laydown parts to arrive. Since then it has only had the laydown in it. Once my 6.1Ds arrive, I am going to try and put the layback transmission in my XT6. Hope it will work. For my outdoor season coming up I have a 4 gear B6 transmission built and ready to drop in and try.
#4047
XFactory chassis
I put the XFactory infinity chassis on My truck and just installed the chassis stiffener side rails. My question is where do I mount the antenna ? There seems to be no place.
#4048
I make an antenna out of body scraps. Put some holes in it and thread the antenna wire through so it does not over lap itself. Then double side tape it some where. Been working 2 years without a glitch, and no hole in the body. We did this in the 90s with cheap AM radios for oval with very little problems.
#4049
