can a helical diff be fliped
can a helical pinion have the ring gear diff flipped to change rotation to prevent from having to run elec motors backwards .
this is on a RB eone R and it seems motors are a bit pickey about being ran backwards on a sensord motor .
so I was thinking just flip the diffs . ugg lets just say im a bit frustrated
if you think about it a little it should work fine. (think like its just rotating the diff around the pinion, so teeth mesh doesn't change, but rotation does)
it might not even be the motor that is at fault. those spiral cut diffs only like to rotate one way relative to the pinion, otherwise the teeth tend to bind up a bit.
flipping should work fine though
Technically they shouldn't be , but in some real vehicles they run the same ring and pinion gear set front and rear. ( land rover discovery for example). And I'm not familiar with the particular car you inquiring about . but if the front and rear bevel gear set are the same part #'s ( very likely) they are already running one diff in a compromised fashion.
Thanks everyone for the reply . The motor was defective go figure in normal it ran perfect but would skip when esc set in reverse( motor direction)
I am going to flip the diffs and make sure the pinions dig not push if they dig im going to flip .
I will reply to let yall know how it goes
well I got the motor back.
I flipped the diffs to run the motor in forward had to grind the front chasiss to clear diff gear .(the reverse still had the same problem)
the good news is the RB e one r ran 2 sec behind tq one of the 2 fastest things at the track for the day and had no problems with the buggy .
I ran at 65 punch anything higher I ran slower lap times .
It felt slow but lap times don't lie was really easy to drive .
so this was the first indoor run and it was off the charts good .
looking forward to going to Batavia in ohio next week for another run
ps I have a back up tekin power system, I don't have time to rma the viper till I get back, plus its all working very good
