Help with electronics for a roller truggy I just purchased
I just recently bought a team associated rc8t. I do still need to buy the electric conversion for it, but I can't seem to pick a good cheap motor esc combo for it. My problem is finding a motor that directly bolt up to the motor mount. The tekno kit says 42mm so I'm guessing the motor diameter has to be the same size. Any help would be greatly appreciated thank you. Oh and a good servo would be great too.
Its for castle / tekin size motors , "up to" 42 mm . So most any popular system should work. Castle has a new 1/8 system for about 160. Hobbywing has theirs for about 210. Lots of choices out there ...
Hitec 7955 servo , buy it used , its a tank.
I went through 2 pro tek servos and never got an entire lap out of them combined. Seems to be hit or miss
I would go hobbywing 150a and either their or tekin 2000 motor if you can swing it, I don't like castle stuff whatsoever. The hitec servo suggestion is good but I would go 7954 over 7955. It's the same at 6 volts as the 7955 but u can add a bec to the hobbywing and run it at 7.4v to get up over 400oz of torque it opposed to 333 @ 6v. And I think it was actually 10$ cheaper than the non hv 7955 version. Smc battery.
