Old 08-12-2005, 07:09 PM   #1
Default Motor jammed
My motor jammed whats wrong? Im having the worst luck.
T3MAN is offline   Reply With Quote
Old 08-12-2005, 07:58 PM   #2
schmelme's Avatar
Not to be rude but before you post at least think it through a little ir you want help details like what kind of motor, nitro or electric what happened when it jammed is it removed from vehicle ect ect...
schmelme is offline   Reply With Quote
Old 08-12-2005, 09:11 PM   #3
Sry. Its an electric 27 turn motor made by epic. I took it out of the car and ran it but it spins then gets jammed until i free it. then it jams agian
Old 08-12-2005, 10:03 PM   #4
Team Duratrax's Avatar
Send a message via MSN to Team Duratrax
Maybe a magnet has come loose on you? Open up the motor and see.
Sean
Team Duratrax is offline   Reply With Quote
Old 08-12-2005, 10:10 PM   #5
Platinum_Racing's Avatar
Send a message via MSN to Platinum_Racing
Did you lose a screw somewhere? If theres a screw inside the motor, that can jam it. The screws holding the motor into the car can also be either too long or too tight. I had a motor sieze up on me before because the crown actually detonated. When the crown failed, it expanded and dug a groove into the magnets before finally coming to a halt. I can't even explain how rare this is, and the only reason it happened in the first place is because it was a worn motor anyway, and I wanted to see what kind of effects I could get by drilling the armature. It was a stupid move, but for the several races I got out of it, it was fast as Hell!
Platinum_Racing is offline   Reply With Quote
Old 08-12-2005, 11:40 PM   #6
JoshR 85's Avatar
HeY!!!
i'd also check the brushes, it may be hung brush, if it will go, then lock up on ya while driving it.... or else if it locks up on ya while it outa car then something is just jammed in it and you have to take it apart.... only other thing i could think of is that it may be bushing melted or seized up on ya...
well hope that helps a little bit...
LaTa JoSh
JoshR 85 is offline   Reply With Quote
Old 08-22-2005, 10:15 AM   #7
Its a magnet that came lose now how do i fix that?
Old 08-22-2005, 11:36 AM   #8
handyrandyrc's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to handyrandyrc Send a message via AIM to handyrandyrc
Just re-attach the magnet with a little epoxy or JB Weld (the best)..
handyrandyrc is offline   Reply With Quote
Old 08-22-2005, 11:39 AM   #9
Casper's Avatar
Trader Rating: 34 (100%+)
Make sure you get the magnet flush against the can if you do try and glue it again. Epoxy or JB weld. CA will not hold. You can try and get another can also. The black can epic motors tend to loose magnets due to the can coating not liking the glue they use. Also ask around. You may find someone at the track who has a worn out stock motor you can put your arm and endbell on the new can.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 4.0, TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 08-22-2005, 11:49 AM   #10
dgullickson's Avatar
Trader Rating: 45 (96%+)
Send a message via AIM to dgullickson Send a message via Yahoo to dgullickson
Let me guess P2K2 can?
dgullickson is offline   Reply With Quote
Old 08-27-2005, 01:54 AM   #11
This happened to my P2K2 can as well. I used CA to fix this.
Sean
Old 03-20-2006, 03:18 PM   #12
Q_man's Avatar
Default p2k2 pro
I am having a problem with my p2k2 pro and hanging brushes. The track is quite dusty and it just looks like dirt is jamming the + brush. It runs fine then just stops the brush is well and truly stuck there. Is there any way to prevent this from happening? Should I replace the brushes?
wayne
Q_man is offline   Reply With Quote
Old 03-20-2006, 03:22 PM   #13
wayne
Quick version:
Take apart the motor and spray out the can and the hoods thoroughly.
Skimm the comm, reshimm and put back together..
Install new brushes and make sure by holding the shunt that the brushes move in and out freely.. Run red and red - break in for 200seconds with a fan. Put green on neg. and break in for another 30 seconds.
Good to go..
Old 03-20-2006, 04:03 PM   #14
Casper's Avatar
Make sure the brush hood is not crushed. The epic cans run pure copper hoods for conductivity and they can be crushed in accidents. Make sure the top of the hood is straight. Use a pair of needle nose pliers to bend the hood back if necessary. The brush should move in and out of the hood freely. There is a small leaf spring in the top of the hood to make sure it is getting good contact but the brush should slide in the hood with minimal effort.
Old 03-20-2006, 06:02 PM   #15
Q_man's Avatar
thanks for the tips i will give them a go.
Quark 4T BL motor, rc18t xps esc, mlst shocks, and xray alloy motor mount. rschoi_75 R/C Items: For Sale/Trade 2 09-08-2011 12:28 PM
Modify your stock motor, mod motor, any motor! TRF-Powered Electric On-Road 10 03-15-2007 05:52 PM
Trinity Motor Checker “Monster Horsepower Machine” Motor Performance Monitor CRiXman R/C Items: For Sale/Trade 5 01-25-2007 03:36 PM
Please help.. My thorttle servo is jammed nitro_moe Nitro On-Road 13 01-02-2007 06:58 PM
fly wheel jammed? Modified_Racer Nitro On-Road 11 12-06-2005 05:57 PM
